Old Feb 7, 2016 | 03:20 PM
whitelt3's Avatar
whitelt3
Default 28/10.5/15
Anyone running a 28x10.5x15 tire on a c6 base? Or any other large drag tire for that matter. Picked up a wheel and tire combo with a 28x10.5Sx15 and I only about about .5 inch all the way around the wheel and am worried about the fender coming down on the tire. Thanks!
Old Feb 7, 2016 | 03:29 PM
C6David's Avatar
C6David
I ran 28x10x17 on mine. 54 offset and it only rubbed on the inside of the fender and on the fender liner.
C6David's Avatar
C6David
And also do you already have rear drag spindles? If not those 15s will not fit.
Old Feb 7, 2016 | 03:33 PM
whitelt3's Avatar
whitelt3
yes, I have drag spindles. I have ran the 28x10x17 for a long time on a c5 17x9.5 wheel with zero clearance issues. This 28x10.5x15S tire is just a big tire!
Old Feb 10, 2018 | 04:10 AM
DKS2K's Avatar
DKS2K
Did you ever find out if they fit?
Old May 2, 2018 | 04:06 AM
Spzany's Avatar
Spzany
ok you have 28 “ on the rear what size are your front runners
To 28/10.5/15
