Replacing Reverse lock Out Solenoid on 2012 M6
Old Feb 11, 2016 | 09:47 AM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Default Replacing Reverse lock Out Solenoid on 2012 M6
Is there a special tool required to replace the reverse lock out solenoid on a 2012 M6? The size is 1 1/16 or 27mm but the deep sockets are 2 shallow. Any hep would be appreciated.
Old Feb 11, 2016 | 10:46 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Would an oil pressure sender socket work? It's a 27 1-1/16" as well. You can get them at any parts store.
Old Feb 11, 2016 | 11:26 AM
Unreal's Avatar
Unreal
Just need the correct socket. I've had zero issues and did mine on the car.
Old Feb 11, 2016 | 05:11 PM
RicK T's Avatar
RicK T
This post disagrees on socket size but offers some tips that may help:
https://www.corvetteforum.com/forums...-solenoid.html
Old Jul 30, 2016 | 08:18 PM
dblais's Avatar
dblais
Default socket
OK again. The original is a 34MM. Buy an impact type deep socket (Autozone). A sear Craftsman 27MM Deep will work for the replacement. Use a 1/2 to 3/8 ratchet adapter. You have to do this by feel as you cannot see on top of the Trans. I did however bored the 27MM socket for a longer depth to engage the hex. Takes all of about 15Min. Mine is an 05 Coupe with M6 Trans.
To Replacing Reverse lock Out Solenoid on 2012 M6
