g force axels
Old Feb 14, 2016 | 11:01 AM
weige's Avatar
weige
Default g force axels
has anyone had a problem installing g force 1320 axels on c6z with coilovers outter cv boot hits spring thanks
Old Feb 14, 2016 | 05:47 PM
timd38's Avatar
timd38
Good question. I thought it looked like there was an interference issue, but it have been a year and the boots are not rubbing. I have LG coilovers.
Old Feb 14, 2016 | 08:42 PM
weige's Avatar
weige
mine are phfat coil overs
Old Feb 15, 2016 | 01:04 AM
xBoostx's Avatar
xBoostx
Is best to drive the car on a lift with the suspension loaded and look for clearance then rather than with the tires hanging cause this way everything is way off geometry, hope this helps.
Old Feb 15, 2016 | 06:43 AM
timd38's Avatar
timd38
If the weather was nicer, I could check. I have one good Pfadt rear coilover in my gagare, but when mine broke I bought LG's.
Old Feb 15, 2016 | 07:30 PM
weige's Avatar
weige
called g force this morning they have a low profile boot for the outer joint.for this case of problem. im glad they can make it work cause these are some bad a,, axels and good people to deal with thanks g force 1320
Old Feb 15, 2016 | 07:46 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Really hope your axles last longer than mine, which was about 14 passes before they started coming apart on me.
Old Feb 15, 2016 | 08:17 PM
weige's Avatar
weige
are they g force axels
Old Feb 15, 2016 | 08:19 PM
Supporting Vendor
Yeah, they were.
Old Feb 15, 2016 | 08:36 PM
weige's Avatar
weige
they have lifetime warrenty
To g force axels
