Thoughts this on cam and install package
Old Feb 18, 2016 | 01:29 AM
napp e roots's Avatar
napp e roots
Default Thoughts this on cam and install package
Looking at doing this in the summer just want to get a feel if this a good price for a package like this
LS Corvettes- $2399.99
Package Includes:
Comp Cams LS 3-bolt Cam selected by customer
Hardened Pushrods
Brian Tooley Dual Valve Springs (cams up to .650 lift)
GM Crank Seal, Water Pump Gaskets, Front Cover
Melling High Volume Oil Pump
LS2 Timing chain
GM Crank Bolt
NGK Spark plugs
Mobil-1 Oil Change and Filter
Dyno Tune with Before and After Graphs
Old Feb 18, 2016 | 07:19 AM
EnviedC6's Avatar
EnviedC6
That seems close. It is usually a 8-10 hour job charged by a shop, where most shops are around 100 per hour. A cam and spring kit will be around 700-800. Then add on the extra goodies and maintenance parts.
Old Feb 18, 2016 | 08:42 AM
jbomx363's Avatar
jbomx363
Compared to some of the vendors who have posted their packages, they are in the $1850-$2200 range
Just depends on where you live mostly.
Old Feb 19, 2016 | 12:09 PM
Speedforhire's Avatar
Speedforhire
The so-called high volume oil pump is NOT necessary on a LS3........the oem flows very well. It would only need to be replaced on an EXTREME build.
Where are you located?
Old Feb 28, 2016 | 08:40 PM
napp e roots
I have an ls2 if that matters and I am in Southeast Wisconsin
Old Mar 6, 2016 | 01:28 AM
Sid1231987's Avatar
Sid1231987
Looks like they're charging you about 1100-1200 in labor. Seems like for that price you should get new lifters and trays as well just my opinion
Old Mar 6, 2016 | 08:44 AM
rjacobs's Avatar
rjacobs
Yes, but then you need to add another couple hundred in labor for pulling the heads plus a bit for head gaskets and bolts.
Old Mar 6, 2016 | 09:36 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
True..
To Thoughts this on cam and install package
