the Boss
Old Feb 19, 2016 | 06:00 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Default the Boss
Does anyone have anything to say about PurolatorBOSS Oil Filters. I saw them at Advance and was thinking about trying one. They advertise 15,000 mile protection.
Old Feb 23, 2016 | 02:26 PM
ls1121's Avatar
ls1121
wow no one?
Old Feb 23, 2016 | 02:48 PM
Lou7787's Avatar
Lou7787
Never used that particular filter. Hopefully someone will come along soon. I just posted so you wouldn't feel ignored.
Old Feb 24, 2016 | 01:43 PM
el es tu's Avatar
el es tu
The Boss filters look good - I might try one next go around
Right now the only ones I go with are (in order):
Napa Platinum
K&N
Mobil 1
Not that other brands arent good, but I like the thicker casings and synthetic materials of the above.
EDIT:
I would not suggest leaving the filter on for 15k miles. Filters should be changed with every oil change, and oil changes should not be occurring at such high intervals.
Even if the oil doesnt wear down (like those 15k oils advertise), it still has carbon in it which over time helps build deposits.
Old Feb 25, 2016 | 04:18 PM
jrose7004's Avatar
jrose7004
I use either K&N or Mobil One myself.
Old Feb 26, 2016 | 10:04 AM
AaronLS3's Avatar
AaronLS3
IIRC Purolator gold filters were made by the same people that make the mobil 1 filter. So its possible this new boss filter will be fine. As long as you don't use fram. I use mobil 1, wix, or delco personally
Old Feb 27, 2016 | 01:25 PM
ls1121's Avatar
ls1121
Thank You
I did buy one yesterday at Advance $29.99 for 5 qt. Pennzoil Synthetic and the filter. Here is the vid I watched.
https://www.youtube.com/watch?v=EmhJ...ature=youtu.be
To the Boss
