Need help with exhaust fitment
Z06 is 3" into the inlet of the mufflers, then goes down to 2-1/2" inside the mufflers.
ZR1 is 3" through the mufflers.
Someone else will need to confirm this.
So you just need to get the proper ARH 3" x-pipe to match your headers, basically a Z06 system. Keep in mind that the 2012's introduced the 2nd set of CATS so you will have to specify if going catless, or with one or two sets of cats (hopefully only one
OP....
2011-2013 Z06 and ZR1 mufflers are identical. Both are 3" and have the same internal construction as the '08 and up NPP mufflers. People like these mufflers due to the sound.
'09-'10 ZR1 mufflers are 3" like the above
'06-'10 Z06 mufflers are 3" like the above but the internal construction is different. The "straight through" side of the muffler used a perforated pipe that makes them a little quieter and have a slightly different tone. People often do the "muffler mod" on these so they sound like the later mufflers. Tons of threads and pics regarding this mod.
Bottom line is you can use any of the above, all will bolt right in and all share the same external size and geometry.
I have a 3" borla touring that I believe came off of a 2008 z06. It's doesn't even come close to fitting.
Your issue is likely with the intermediate pipe you are using.
The Grand Sport uses the base 2.5" exhaust system. Therefore, the over-axle pipe geometry is the same as the over-axle geometry as the 2009 & up base system and it differs from the 2008 and earlier base geometry.
You stated in your original post that you are using a 3" system. The 3" systems ONLY came on the Z06 and ZR1. Therefore any changes to the base/Grand Sport system are a totally mute point. There was NO change in over-axle geometry for the 2006-2013 Z cars.
You need to identify exactly what parts you are using. I'm beginning to think you have a mix of base and Z parts which is a hack job at best.
To assume my car is a "hack job at best" actually pi**es me the f*ck off as I have spent over 25k in modifications to the car. I clearly purchased the wrong axle back and I'm trying to determine exactly what exhaust I should be looking at that will accommodate 3" all the way back to mate up with zr1 arh headers and fit over the axles of my 2012 grand sport.
The "over-axles" as you call them are part of the muffler. Some companies leave them loose to ease install, but from an OEM perspective they are all one part. If you have 3" pipes, they will fit all the 3" (aka Z06 or ZR1) intermediate pipes out there.
We know you have a GS. Want a 3" exhaust? Read this thread
Swap out the LS7/9 exhaust manifolds/cats for your Z car headers, buy the correct intermediate pipe for those headers, and bolt on ANY Z06 or ZR1 mufflers, OEM or aftermarket. As mentioned above, I suspect your issue is that you have the wrong intermediate pipe.
Since you are clearly confused and don't know what your asking about.....The geometry changes are on the passenger side of the 2009 & up base & GS intermediate exhaust pipe and the muffler over-axle pipe. The car geometry, attach points, etc are the SAME on the GS as they are on the Z06 and the ZR1.
The actual, literal, no sh*t, we're not kidding exhaust PIPE is what changed. You're so f'ing wrapped around the axle about a geometry change yet it doesn't even apply to you if you're using a full OEM or aftermarket Z06/ZR1 exhaust.
Lastly, if you were trying to use any base or GS exhaust parts with your Z headers, then it's a hack job. Doesn't matter if you spent $25k on mods. You would be trying to force parts to work together that require cutting, massaging, and adapters to do so....aka hack job.
Go buy the right intermediate pipe, if your over axle pipes were loose from the mufflers ensure you're using them on the correct sides, and quit worrying about a geometry change that doesn't apply.
On the passenger side of the car (base and GS ONLY) the passenger midpipe discharges at a different angle on 09+ cars. The corresponding muffler matches up. This is why 09+ axles back systems are incompatible with previous years. I uncovered this issue when installing a rear mount turbo system designed for an LS2 onto a '12 GS. It simply required cutting, rotating, and welding the axle pipe, but that is what is going on here. Everything else matched up. As said, you won't be dealing with this design change anyway if you go to a 3" system, so the point is moot.
Next how big is the connection point where the X pipe connects to the axle back? Again if it is 3" then it's the right one. If it's necked down to connect to a 2.5" then it is the wrong one regardless if it's made for the 05-08 or the 09-up. You need the X pipe made for the ZR1 which I'm guessing you have.
Anyways, I will be shipping this exhaust back and continue my hunt on finding one that will fit my car properly.
