Ls3 exhaust Question
I have a 13 grand sport 6 speed car. It's still under warranty until 2019. Trying to do little things that won't void my warranty. I saw that ls7 exhaust is a good upgrade. Couple questions.
1. Is the older ls7 exhaust an hpipe also, and if so should I look for hpipe or xpipe?
2. I love the way the npp exhaust sounds, so would I be to just modify the
2.5 inch rear section, to the 3 inch mid pipes? And if so would that be smart or not as it may create a pinch point in exhaust flow?
3. Any need for different O2 sensors??
If I can pickup 10-15 hp by spending a couple hundred dollars, and retaining warranty that would be a win for me. Any help would be great appreciated. Thanks.
2. The LS7 3" exhaust reduces to 2 1/2" at the muffler inlet so it is a simple cut and weld job to attach your NPP mufflers to the LS7 pipes. Just make sure to measure and cut carefully. Many have done it over the years.
3. As long as you are using the LS7 manifolds your O2 sensors will fit fine.
