C5 Diff Swap ???'s
Old Mar 13, 2016 | 10:22 AM
H82BRAG's Avatar
H82BRAG
3rd Gear
Default C5 Diff Swap ???'s
I have one of the infamous 05 m6 peanut brittle differentials.....and Im looking at a swap. Ive narrowed it down to the 3-rib c5 diffs. I found one from an 01 z06 and one from what I assume is an auto c5 (3.15 ratio). I just want to verify that I can use the auto style diffs if I choose. Also I remember seeing a couple members making adapter plates to mount the c5 diff in a c6 cradle. Hopefully they are still on here I would be interested in one....I could prob fab something but Id rather use something I know is a good piece. I currently have an ls2 with cam full exhaust vararam and nitrous outlet kit. I dont want to run the nitrous until I do something about the diff. Rather be safe than sorry.
Old Mar 13, 2016 | 11:04 AM
hippy's Avatar
hippy
I don't "think" you can use the auto diff as the trans output shaft maybe splined differently. I know in C6 diffs that is the case and I will assume the same to be true for the C5 diffs too. Were you planning to change the gears out in the auto diff to 3.42 or higher?
Old Mar 13, 2016 | 11:09 AM
H82BRAG's Avatar
H82BRAG
3rd Gear
Yes I planned on going 3.73 when I do it. I was just curious as I figure a z06 diff prob received a little more abuse than a base model or auto...I am not sure myself about splines. My intention is full rebuild (ring and pinion, hardened shafts, bearings and races) before install so I would imagine that would remedy any potential input shaft differences if they are in fact different. I just don't wanna get involved in 06+ stuff because then I'm changing the case on trans.....lot more then a c5 swap
To C5 Diff Swap ???'s
