radiator shroud push pin sizes
Old Mar 14, 2016 | 10:58 PM
rjacobs's Avatar
rjacobs
Default radiator shroud push pin sizes
Im re-installing my radiator shroud and I guess I destroyed all the factory plastic push pins when removing it.
There are 2 that go from shroud to condenser.
4 that go from shroud to inner air dam(2 on each side)
and 2 that go from shroud to crash beam(these are a two piece pin)
I dont need them from the dealer, I can get them just about anywhere, just need sizes, or approx sizes.
Old Mar 16, 2016 | 02:40 PM
Dcasole's Avatar
Dcasole
I am not sure of the sizes but I just went to O'Reilly Auto Parts , they had more than a few sizes , I just matched up what I had in my hands
Hope this helps ....
Dave
Old Mar 16, 2016 | 07:47 PM
rjacobs's Avatar
rjacobs
Dave
yea problem is I dont have any of them. Im sure I broke/cut them all and they went into the garbage at cleanup time.
Im probably just going to use a drill bit to get the hole size and get something close.
Old Mar 16, 2016 | 08:19 PM
Cherokee Nation's Avatar
Cherokee Nation
Go online to GM parts Direct or GM Parts House.BTW that big piece of plastic is called the Baffle' not shroud.
Old Mar 17, 2016 | 12:06 PM
rjacobs's Avatar
rjacobs
They are listed on the diagram, but not in the parts list so you cant buy them. I'm sure I could go to the dealer and pay $5 per, but im not going to do that.
Just figured somebody knew the shank size.
Old Mar 17, 2016 | 03:45 PM
05 Wreck's Avatar
05 Wreck
When you find the sizes you need, look here:http://dixied.com//page21.html
I'm not recomending you buy here, they're shipping is too expensive. Find the correct AuVeco product and go to ebay or amazon.
To radiator shroud push pin sizes
