No fuel pressure NEED HELP
Old Mar 16, 2016 | 09:29 PM
Ltfwraps's Avatar
Ltfwraps
5th Gear
Default No fuel pressure NEED HELP
Hi can anyome help me out.
I cant start my engine
I got spark when I cranking but no fuel are coming to fuel rail.
Checked relay amd 20amp fuse they are ok. What could it be ?
Old Mar 16, 2016 | 10:04 PM
jamestronix's Avatar
jamestronix
It could be the fuel pump. Can you hear the pump come on for 2 seconds when trying to start the car?
Old Mar 17, 2016 | 05:30 AM
Ltfwraps's Avatar
Ltfwraps
5th Gear
No, i checked pump doesnt turn on, no fuel are coming to fuel rail.
Old Mar 17, 2016 | 09:36 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Swap fuel pump relay with another one that is used for the AC or something like that that you can spare for testing purposes.
Check fuse as well.
Old Mar 17, 2016 | 08:43 PM
Purple92's Avatar
Purple92
Or - you can put power directly to the fuel pump when you pull the relay out. (I'd do this with a fused jumper lead). See sticky on fuel draining. You should be able to hear the fuel pump run when you apply power to it.
Old Mar 17, 2016 | 08:45 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That too. I figured swapping the relay was the easier first step
Old Mar 19, 2016 | 11:24 AM
Ltfwraps's Avatar
Ltfwraps
5th Gear
Guys all sprted !!!! It was fuel pump just stuck, there was low on fuel !!
Old Jun 26, 2016 | 02:12 PM
liuhisn's Avatar
liuhisn
Default Car won't start
I did not reset the timing.
Old Jun 26, 2016 | 04:11 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Ok?
To No fuel pressure NEED HELP
