Fast 102 Items for install
Old Mar 19, 2016 | 06:35 PM
Mazen123's Avatar
Mazen123
Default Fast 102 Items for install
After searching around the internet and the forum on whether I need new fuel rails, injectors or injector spacers to insall a fast 102 on my LS2 Corvette, Ive seen very mixed answers.
Do I need different fuel rails, injectors or injector spacers to install a fast 102 intake on my LS2 C6 Corvette?
Old Mar 19, 2016 | 06:44 PM
timd38's Avatar
timd38
You should not need spacers or rails. If you use LS3/7 injectors, you need spacers, but not if you use LS2 injectors.
Old Mar 19, 2016 | 06:46 PM
Mazen123's Avatar
Mazen123
Thanks for the reply, My injectors are stock ls2 as are my fuel rails. So I should be good to go on just the fast 102. Thanks again
Old Mar 19, 2016 | 07:00 PM
timd38's Avatar
timd38
Yup! I put an LS3 top on my LS2 with a FAST and used my LS2 injectors and rails. Later, I upgraded to a strocked LS3 and I upgraded the injectors, so I had to use spacers. I ended up with Holley rails also, but stocker work. The fuel rail covers are an issue, but you can leave them off.
I went a couple different ways with covers.
First setup.
Current
Old Mar 19, 2016 | 07:52 PM
Mazen123's Avatar
Mazen123
First setup.
Current
Looks awesome either way! Will I be able to use my stock covers with the fast? Ive heard of people trimming them and modifying them. I had my stock covers paint matched to my car so I would like to keep them.
Old Mar 19, 2016 | 08:13 PM
493lszosix's Avatar
493lszosix
Not sure of the difference between the ls2 covers and my ls6 but I just trimmed mine down with a dremel to fit
Old Mar 19, 2016 | 09:54 PM
timd38's Avatar
timd38
You can trim them, but I am not good at that kind of stuff!
Old Mar 20, 2016 | 11:52 AM
irok's Avatar
irok
Default yes
your stock fuel rail covers will work fine with no trimming needed.everything fits.mine fit perfectly
Old Mar 20, 2016 | 02:50 PM
timd38's Avatar
timd38
Interesting, mine did not, wonder if it was becasue I went with LS3 heads and intake, but I did try both LS2 and LS3 covers.
Old Mar 20, 2016 | 11:21 PM
hippy's Avatar
hippy
My LS2 covers fit after just a bit of dremel work on a few areas to clear a couple runners on my fast ls2 intake.
Old Mar 21, 2016 | 01:27 PM
tennblkc6's Avatar
tennblkc6
yeah...i may need to do this as well since my frc do not fit real well in stock form.
To Fast 102 Items for install
