C6 Auto TCS & Active handling problem
Old Mar 29, 2016 | 07:50 PM
tertiumquid's Avatar
tertiumquid
Default C6 Auto TCS & Active handling problem
I have a 2008 C6 auto with 72k miles on it. It's never had a problem until this morning. After driving it 10 miles at normal commute speeds, the TCS light came on, followed soon after by the active handling light and then it downshifted to 2nd gear and wouldn't shift up or down. The paddle shifters didn't work and then the check engine light came on. I had to drive it home at 25 mph and took the other car to work. When I started it tonight, it runs normal, auto shifts fine, paddle shifters are ok and the TCS and AH are out but the check engine light is still on. The only other thing that seems different is the oil pressure is higher than usual, even when warmed up it usually is around 30psi but now is closer to 45-50psi. Any thoughts before I drag it to a dealer?
