Raising car
Old Mar 30, 2016 | 10:29 PM
bcc101's Avatar
bcc101
Default Raising car
While waiting for the weather to break I thought I would get the car up on my EZ car lift and install a license bracket and do a little touch up under the front.
My intention was to jack up the car and place some 2x wood under the tires to get some clearance for the lift.
My small 2 ton jack would not fit under the front.
I was trying to avoid starting it for the short time to drive the car on blocks.
Is there a jack that fits under the car?
Bruce
Old Mar 30, 2016 | 10:38 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
Bruce
I got one at the Chinese tool store. The big box tool places.
U just need one that claims to be able to get under low cars.
Not expensive at all.
Robin
Old Mar 30, 2016 | 10:41 PM
Suds's Avatar
Suds
I use this jack from Harbour Freight, and my car is fully lowered on stock bolts.
Old Mar 31, 2016 | 11:03 AM
jrose7004's Avatar
jrose7004
I got a low profile aluminum floor jack from Harbor Freight.
Old Mar 31, 2016 | 12:22 PM
torquetube's Avatar
torquetube
Will your jack fit under the sides? You can lift from the same pads you'll use for your EZ lift in order to place the wood blocks. You won't bend the car.
Old Mar 31, 2016 | 12:35 PM
bcc101's Avatar
bcc101
I should have finished the sentence. The 2 ton jack would not fit under the car to reach the front jacking point.
What I intend to do is raise the car and put some 2x wood under the tires to raise the car sufficiently to get the EZ lift underneath.
I do not want to start the car just to drive it on ramps and with the weather will not be on the road for a few days.
Off to the Chinese store tomorrow.
Bruce
Old Mar 31, 2016 | 01:06 PM
CMY SIX's Avatar
CMY SIX
Bruce
your first Idea will work, jack the car up on the side, it will pick up both front and rear wheels, I had 2x12's cut in 1 foot pieces put a piece under each tire, lower go to other side do same thing, only you will find you can put two pieces under now, I did this until I had 3 pieces under the front, 2 rear, now I put the jack in the middle of the front cross member and jacked it up and now put jack stands under. I've done a cam job and front brakes so far plenty of room.
Old Mar 31, 2016 | 03:02 PM
victorf's Avatar
victorf
delete!
Old Mar 31, 2016 | 03:50 PM
icntdrv55's Avatar
icntdrv55
Originally Posted by victorf
...high enough to slide my home made(or any suitable height stack of cinder/wood block) stands under one side....
I'd love to have a welder to fab some of those nice stands you've got! Just a comment, though, on your suggestion to use cinder blocks. I KNOW there's 10 million junk cars sitting on blocks in front yards across the US for the last 50 years, but....should the blocks fail, they fail catastrophically, shattering into dust and leaving no safety margin for escape and/or survival. Leave the cinder blocks to the hillbilllies....
Old Mar 31, 2016 | 04:16 PM
WW7's Avatar
WW7
I live in West Virginia , and the hillbillies here are now using wood blocks , not cinder blocks...Some of us high class hillbillies even use 4 post lifts to raise our cars, who would have guessed........WW
Old Mar 31, 2016 | 07:54 PM
victorf's Avatar
victorf
Clearly, I shown the home made stands...but never described how to make them.....
Much like the two suggestions on cinder/wood blocks....never described how to reinforced them - before use...
At face value, taking out of context - it is true what you said about naked cinder block...much the same with wood stack that can split under pressure....
What I posted were mere suggestions for someone without resource or basic skills....they were suggestions to explore possibilities to use "other" materials.
I find myself make less and less posting - suggestions to think outside the box.....
Old Mar 31, 2016 | 11:47 PM
icntdrv55's Avatar
icntdrv55
victorf: I really wasn't criticizing your post. Simply a matter that many folks may not even think of the safety issues when using a brittle support like a cinder block. And to the correction posted by WW7....mea culpa, mea culpa, mea maxima culpa. Not PC to use such a term. How about we agree to use the term "backyard mechanic"....?
Old Apr 1, 2016 | 07:09 AM
Grimlock13's Avatar
Grimlock13
though I bought a craftsman low profile aluminum jack.
It doesn't get very high lift but it is enough to put blocks under tires, change tires, etc.
To Raising car
