K&N Drop-in filter VS full intake
Just wanted to see what everyone's opinion was of buying just a high performance drop in filter like this one:
vs going with the full intake unit which is usually 3 or 4x in price.
Looking to put this on a California 2008 base 6.2L Z51 with hopefully a z06 exhaust and maybe a tune.
THANK YOU!
Kevin
So some air filter will state that they will outflow the stock filter, but at a cost to how much crap they are allowing to pass through instead.
So to make this simple, breath in all the air you can in your lungs, and then tell me if all the air in the world that you have not breathed in, is going to help you breath in more air in the lungs instead.
Now if you are talking a cold air system that is drawing all it air in from outside the engine bay areas (instead of just from under the hood), then that will make a difference. Hence the hotter the air the motor is pulling in, the more the motor will retard the spark instead.
As for a real CAI system, the trick is finding one that is not sucking the air in from low in the front of the car, hence low enough that if you go through deep enough of a water puddle, you not sucking in water to the intake to cause the motor to hydro-lock destroy itself isntead.
Hence if Gm Did it right, they would have mounted the intake to the air filter to pull air in from the front of the windshield instead. At speed, there is a huge pressure wave back towards the hood, and this would allow the motor pull in as much cold air as it would if mounted forward (plus not run into the problem of sucking in water, since water and ran would just be flowed up and over the windshield isntead.
Amazon.com: K&N E-0782 High Performance Replacement Air Filter: Automotive
THANK YOU!
Kevin
Just my 2 cents.
K&N is the best filter you can buy. If oiled correctly they filter 99.9% of dirt. I have one in a Z06 intake and I cut the 2 slots out of the bottom of the baffle to get cold air in to it and it sure makes a different.
K&N is the best filter you can buy. If oiled correctly they filter 99.9% of dirt. I have one in a Z06 intake and I cut the 2 slots out of the bottom of the baffle to get cold air in to it and it sure makes a different.I had the Halltech MF 103 air intake with Beehive Shroud. Installment was easy, no cutting. The filter was a K&N filter designed to Halltech's specifications. The filter remained in the stock location with a top shroud that helped keep hot engine temps away from entering the filter. Look at the chart Dano523 provided and you will see how much timing is pulled. It doesn't take long for the IAT's to rise sitting at a stop light.
The best gains when selecting a CAI is one that reduces engine heat from entering the engine. A simple filter swap might give you a few hp at most which you will not feel. The stock air filter is excellent, but the location is not desirable. My Silverado truck has an oem CAI that feeds cold air from the front fender, like many production vehicles.
Another option is to buy the K&N filter and purchase Halltech's Beehive shroud, separately and modify the shroud to fit the stock intake. Many have done this simple mod.
I would do the Halltech, Z06 exhaust, then tune. Simple bolt ons that will benefit future mods or benefit keeping it as is. Just my .02cts.
with the Green High Performance filter. If you are not happy with the Vararam for any reason we will take it back and pay the shipping both ways! Call us at 713-477-8100
On a California-neutered LS3, I wouldn't spend the money on a CAI. Just pop the shroud, if that still works the same on an LS3 as it does on an LS2. Then get a full Z06 exhaust and a tune. If you want more, and you're not looking to go FI, N20, or stroker, get a set of gears. This would make for a very fun and reliable car without sacrificing daily drivability or spending too much money.
