Upgrades with Cam Install?
Old 04-07-2016, 09:43 AM
dustbusterplus
dustbusterplus's Avatar
Default Upgrades with Cam Install?
I'm shopping around to get a cam install on my LS3 A6. I have a pretty good idea of the specs of the cam, but was curious if there are any other maintenance items to have done at the same time.
I am planning to have the crank pinned while they are in there to make a supercharger that much easier if I were to go that route.
Please let me know if there are any other items I should have addressed that I can save labor on while they are in there.
For reference, my car is a base LS3 A6 w/ 40k miles.
Old 04-07-2016, 10:25 AM
dmoneychris
dmoneychris's Avatar
I've been looking into a somewhat mild street cam for my 2013 GS MN6. The shop I've been working with recommended to get a set of Shaft Mount rockers to add valvetrain stability & longevity to my build. They are pretty expensive though. Personally, I'm going to hold off on a cam for my car until I can afford, (w/extra mod money) to buy the shaft mount rockers & cam at the same time. (Personally, I don't mind waiting a while so I can get a rock solid build)
(http://texas-speed.com/p-359-comp-ca...2-engines.aspx)
Old 04-07-2016, 10:31 AM
0Daniel@Vengeance
Former Vendor
Daniel@Vengeance's Avatar
I highly recommend the following with any camshaft install, with the exception of the obvious gaskets/seals/hardware:
Melling high volume oil pump
C5R timing chain
Trunion upgrade
ARP camshaft bolts
Dual valve springs
Hardened pushrods
We do include all of these parts as well as the 3-bolt conversion for our camshafts and all gaskets/seals/hardware for install in our Cam Kit Plus if you're interested in running one of our grinds.
http://vengeanceracing.net/vengeance...plus-1446.html
Feel free to give me a call or e-mail at david@vengeanceracing.net if you'd like to discuss anything further!
- David @ Vengeance
Old 04-07-2016, 11:52 AM
myredhead1
myredhead1's Avatar
Should probably look at higher stall converter and transmission cooler. Without one, after the cam install, you will be standing on your brake pedal to stop the car from launching at every red light. If you are not doing the work, the stall install will cost just as much as the cam instal. Both will require a tune so best to do together.
To Upgrades with Cam Install?
Quick Reply: Upgrades with Cam Install?
