Critique my run
Old Apr 9, 2016 | 03:03 AM
loosecannonzs's Avatar
loosecannonzs
Default Critique my run
I ran @ PBIR tonight and it was about 1600 DA (I think) 75 degrees and 56% humidity.
My c6z is stock minus the Michelin Pilot SS. I ran the tire pressure at 26.
The track prep was "meh" like usual and I let the car cool some before this pass. I think the coolant temp was 191 by the time I got to the line though.
My trap speed seems kinda low compaired to the magical online results.
I only picked up 24.5 mph on the big end.
Here is a video of the run.
Thanks in advance!
Old Apr 9, 2016 | 09:14 AM
Brandon619's Avatar
Brandon619
I am no expert by any means but I think you can launch at higher rpm and shift at an higher rpm. Look at the ranger launch method he gives very good tips on launching. FYI flush that clutch fluid.
Old Apr 9, 2016 | 10:10 AM
Pitufina's Avatar
Pitufina
I agree that you can launch a little higher and do a quicker slip clutch/wot motion. I've gotten 1.70 with bridgestones all weather tire with over 600rwhp. The DA is not great for hero runs on my experience every time the 60' drop the mph go up as well. I can see you running low 11s as it is with more practice.
You need a little more heat on those tires.
Old Apr 9, 2016 | 11:05 AM
loosecannonzs
After watching the video, my burn out was a good bit shorter than it felt. You are probably correct about heating them up. My second run I tried to launch about 300rpm higher and transition to WOT sooner and spun really bad.
I think I'm done at the track until I change the exhaust valves and do cam, intake headers, and tune. The exhaust valve horror stories scare me.
Old Apr 9, 2016 | 11:14 AM
Pitufina's Avatar
Pitufina
The track prep has to be good too. A little bit more heat could've made the difference. I didn't even lowered the tire pressure on mine.
Old Apr 9, 2016 | 11:36 AM
loosecannonzs
Ok thanks for the input. You think my shift points hurt my mph on the big end that bad? 24.5 mph pick up seems low.
Old Apr 9, 2016 | 01:47 PM
pmwinc's Avatar
pmwinc
I watched you run...did good off the line...no bog, but no wheelspin....I like the 11s with no mods to speak of! I had the silver C6 there...
Old Apr 9, 2016 | 02:47 PM
Pitufina's Avatar
Pitufina
What's your shift point? Stock engines run best shifted right at redline. Your shifting isn't that slow but powershift can also slow the car down since it spins on every shift. At least mine did.
Old Apr 9, 2016 | 09:39 PM
loosecannonzs
Hello. I made 3 passes then left. I went 11.79@120 with a 1.91 60ft (I tried to run out 3rd gear and hit limiter.
2nd pass it spun real bad and I just cruised.
3rd pass was 1.975 60ft 11.70@121.XXL
Did you get any good runs in? I was just talking to people and not really watching people run.
Old Apr 9, 2016 | 09:47 PM
loosecannonzs
I'm not offended but you said "not that slow ". I thought I was shifting good (could improve slightly on the 2-3). I was shifting between 6,900 and 7,000 1St - 3rd, but I shifted slightly early into 4th because it's so close to the trap. I shifted 3-4 about 6700ish. And yes I was no lift shifting except a slight lift going into 3rd.
Old Apr 10, 2016 | 12:14 AM
loosecannonzs
Well actually I'm guessing at my shift points since I'm not data logging and there may be a small deley on tach vs actual rpm. Another question. What is the factory ls7 rev limiter set at?
Old Apr 10, 2016 | 02:28 AM
loosecannonzs
Ok I'll recant my comments on shift points. I watched the video in full screen and looks like I am short shifting around 6700 ish from the camera point of view. Back to the drawing board. I still appreciate critiques though.
I half *** pay attention to the tach and more go by feel, but since my mph is kinda low it might be all driver error. I've ran 7 passes in this car and maybe my excitement/ lack of wheel time is the ultimate factor in only running 123 mph (last week).
I really wish I didn't know about the ls7 exhaust valve horror stories so I would feel comfortable going back to the track Friday after Friday and perfecting the craft.
Old Apr 10, 2016 | 02:30 AM
loosecannonzs
My car is an 08 with 18xxx miles on it.
Old Apr 10, 2016 | 12:09 PM
hippy's Avatar
hippy
I going to guess 7100 based on my LS2 being set at 6600.
To Critique my run
