C6z Auto swap codes
Old Apr 15, 2016 | 04:55 AM
C 5's Avatar
C 5
No Time!
Default C6z Auto swap codes
Over the winter I had my 2008 Z06 auto swapped, I love the swap and everything it includes, however there are a few things that are stopping me from enjoying the car and getting through inspection/emissions.
Here are the codes that I have that I am looking to get rid of.
[] P0713 - Transmission Fluid Temperature Sensor A Circuit High (Pending) (Old) (History) (Current) (Immature)
[] P0803 - Upshift / Skip Shift Solenoid Control Circuit (Pending) (Current) (Immature)
[] P0808 - Clutch Position Sensor Circuit High (Pending) (Old) (History) (Current) (Immature)
a worthwhile mention, I recently installed a skip shift eliminator solenoid in hopes of getting rid of the code, but no luck.
Old Apr 16, 2016 | 08:51 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Was it not custom tuned after? Those codes are easily removable.
Old Apr 18, 2016 | 02:27 PM
cclive's Avatar
cclive
I may be missing something or misunderstanding but how can you put a skip shift eliminator in if you have an automatic trans. Also, since there is no clutch, the TCM is having trouble finding a clutch position signal...
Old Apr 18, 2016 | 05:26 PM
C 5's Avatar
C 5
No Time!
I'm not sure what happened. I was told it was tuned out, but I ended up going to HPtuners and disabling a cel for those codes, unless there's anything else I can do to take them out? So they aren't reported at all or something.
Old Apr 18, 2016 | 05:28 PM
C 5's Avatar
C 5
No Time!
Because the computer is still looking for the signal for the solenoid. I figured it's worth a shot plugging an eliminator on the harness. And yes that's the whole issue with the car looking for a Clutch position sensor and other sensors. I'm looking for a way to disable them/do whatever is necessary to run without codes.
Old Apr 18, 2016 | 05:56 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Hmm.... they shouldnt be on... We have done a ton of auto swaps and never had an issue
To C6z Auto swap codes
