Harmonic balancer wont install deep enough
Old Apr 28, 2016 | 12:57 PM
Hittinboost's Avatar
Hittinboost
Default Harmonic balancer wont install deep enough
Hey guys, installing an ati balancer, and running into some issues. I have an install tool and started drawing the balancer on the crank. The first 90% of it pressed on with some decent resistance on the wrench but went on nicely. But now it's about 1/8" away from lining up to the other pullies and the install tool just stopped dead in its tracks. It won't draw the pulley on anymore. I'm wondering if this is common and whether I should install the crank bolt and sinch it down to about 240ft-lbs to see if it draws the pulley the rest of the way on...any thoughts?
Old Apr 28, 2016 | 01:02 PM
CMY SIX's Avatar
CMY SIX
it does not line up with the end of the crank
Old Apr 28, 2016 | 01:05 PM
Hittinboost
I understand there is a certain hub snout depth...but that aside it's about an 1/8" from lining up from the other pullies. I can only get so much torque on the install tool with an open end wrench, that's why I'm wondering if torqueing down the crank bolt will draw it on the rest of the way.
Old Apr 28, 2016 | 01:11 PM
extrapilot's Avatar
extrapilot
Is the face of the crank still below the surface of the HB? It should not be even, as it would not tighten down correctly. I would not use the CS bolt to draw it up, as that could lead to pulling the threads out of the crankshaft end.
I would wait for others to chime in on this one.
Old Apr 28, 2016 | 01:14 PM
extrapilot's Avatar
extrapilot
You should be using the box end of a wrench as the open end will flex around the tool.
Hittinboost
Yes the face of the crank is still below the hub face of the damper.
Old Apr 28, 2016 | 01:28 PM
Hittinboost
When I take the install tool out and run the ARP bolt in it, there seems to be allot of engagement on the threads (it turns in quite a bit). So I'm not hugely concerned about pulling the threads, but obviously it's still a concern.
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Have you put a belt on it to confirm? They are really hard to judge by eye
Old Apr 28, 2016 | 01:29 PM
Hittinboost
Hey schpenxel, I haven't tried that but I will.
Old Apr 28, 2016 | 01:30 PM
Hittinboost
I also thought about running a straight edge from the tensioner up top down to the crank pulley
schpenxel's Avatar
schpenxel
St. Jude Donor '15
yeah, I mean it doesn't have to be fully on, but putting it on an accessory or two will make it easier to see where it's at
Old Apr 28, 2016 | 01:32 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
can't hurt. anything to check it vs. trying to eyeball it. laser alignment tool is best but not the only way to make sure it's in the ballpark
Old Apr 28, 2016 | 01:42 PM
Hittinboost
Put the ac belt on...it looks really really close. Think I'm gonna torque the crank bolt down and see where I'm at.
Old Apr 28, 2016 | 01:44 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Good deal. Another guy in the FI forum had the same issue when installing an IW balancer and thought he didn't get it on all the way.. but it was, so I bet you're fine
What kind of install tool are you using?
Old Apr 28, 2016 | 01:46 PM
Hittinboost
Summit install tool for LS engines...nice tool has a bearing on the end for the damper hub.
http://m.summitracing.com/parts/sum-900135
Old Apr 28, 2016 | 01:52 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Gotcha, yeah that's the one I used too, it's a nice piece
Old Apr 28, 2016 | 01:53 PM
extrapilot's Avatar
extrapilot
Don't forget the assembly lube that APR packages.
To Harmonic balancer wont install deep enough
Old Apr 28, 2016 | 01:54 PM
Hittinboost
Good looking out!
Old Apr 28, 2016 | 02:28 PM
Chiselchst's Avatar
Chiselchst
$0.10 says it's on tight... (right Sammy?)
Good looking out!
Old Apr 29, 2016 | 10:44 AM
irok's Avatar
irok
if your within an 1/8" you have gone as far as your tool is designed to go.torque to 240 factory spec with your old bolt. remove and replace with new ARP
