Need help routing this PS line, it's the one that connects to the rack (the passenger side-most hole). You can see it looks like it's hitting some of the hard brake lines. This doesn't seem right. Does it need to go to the right of those brake lines instead of the left of them?
It looks like you have the "short" high pressure hose design which is harder to get back into place than the "long" design that they swapped to later. If it will fit around those brake lines I'd put it the other way.
Hard to see in this pic, but I think it shows it going to the right of that brake line and then up and around the other PS hose.
