C6 Radiator Compatibility?
Needing to order a new radiator. Currently putting a lot of maintenance into the vehicle so I'm looking at replacing the current leaking one with a stock used one. I have an 05 Z51 M6 so the radiator has the engine oil coolers built into it. I'm looking at one from an 07 Z06 that looks like it has the coolers, and looks similar size. Does anyone know for sure if it would work in mine? The Z06's part number is 10353890, mine is 10353889.
Make sure the one you're wanting to install has both coolers if you want something that will just drop in
So if your going to go with a OEM style, get a new one, since the problem is the age of the plastic that causes the problem in the first place.
So from Walmart for the 05 z51, ACDelco 21539 with both coolers on the sides, for $383.94 brand new.
http://www.walmart.com/ip/46949062?w...487888&veh=sem
If you want the RADIATOR - GM (10353889), then here for $398 instead.
http://www.cheapestgmparts.com/oe-gm...FRCRaQodaeACCA
If you want to take HOXXOH up on his offer, to install a air cool cooler up front in the noise, and use a single side cooler radiator, then the after market side side cooler can be had for around $125 isntead.
Hence on the later z51 cars, they put a small cooler in front of the radiator in the nose of the car, instead of putting it as part of the side end cap of the radiator isntead.
Good luck
Well worth the money and is also a perfect fit.
