2007 Z06 throwing codes
Old May 13, 2016 | 08:50 PM
r2boxers's Avatar
r2boxers
Default 2007 Z06 throwing codes
I was driving the other day and had just stood on it on the freeway. Continued speed with a slight hesitation and then ran perfect for the rest of the day. It did throw code P0102 which is Mass or Volumne Air. Do I have a bad MAF? No problems since. Took car into body shop and noticed it came back with code P0622 which is generator fields. Could this be due to them letting the battery go dead and then jumped it. Again, car runs fantastic. Puts out 14.2 - 14.5 running down the highway. Is this something to be concerned with? Thanks for looking.
Old May 13, 2016 | 08:51 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Stock car/tune or what?
Old May 13, 2016 | 09:32 PM
r2boxers's Avatar
r2boxers
It is a stock Z06.
Old May 13, 2016 | 09:43 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'd replace MAF first, clear code, see if it stays gone
P0102 means the MAF signal is too low.. so that would make sense with a failed MAF.
Old May 13, 2016 | 09:58 PM
r2boxers's Avatar
r2boxers
Cleared code today. Will drive for awhile and see if it throws code again. When it does, new MAF will be installed. Thanks for your help!
Old May 14, 2016 | 05:43 AM
Dano523's Avatar
Dano523
Would start by pulling the MAF to give it and it connectors a good spray electrical cleaning. Hence could be the coils are oil debris packed, or you may have gotten water in its connector to reek havoc instead.
Next what air filter assembly, since some after market filters/housing can reek havoc on the MAF sensor readings as well. Hence instead of a smooth flow of air past the Maf for a clean reading, they cause turbulence isntead.
Also, when you have the maf out and cleaning it, check the code on it.
https://www.corvetteforum.com/forums...d-effects.html
As for the charger/battery-code/problem, dead battery will cause all kinds of strange codes. So once you have the battery charged again (battery tender), clear the codes and see if they come back again.
Old May 14, 2016 | 01:42 PM
r2boxers's Avatar
r2boxers
Will remove MAF today and clean it up. I am running a Callaway Honker for intake. Filter is new and fresh. The car was not dead when I picked it up, that was just a thought. As mentioned when running, it puts out 14.3 to 14.5 volts always. I cleared codes yesterday and is on my tender when not driving daily. Will let you know the condition of MAF when removed. Thanks for your input!
Old May 14, 2016 | 07:00 PM
r2boxers's Avatar
r2boxers
Took MAF out and cleaned all contacts and MAF itself. Took for drive and no problems at all. Did check for codes after driving and it was clear.
Old May 14, 2016 | 10:12 PM
Dano523's Avatar
Dano523
Yep, with filters that you have to clean and oil (read over oil with the oil getting suck through the Maf), you may have to pull the MAF and clean it after a filter cleaning.
Plus, the with the way the car vents out of the motor into the intake, not uncommon for the PCV system to oil debris the MAF with out having a filter that is cleaned and oiled.
Old May 15, 2016 | 09:33 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It is a stock Z06.
Does not compute
Old May 15, 2016 | 03:01 PM
cclive's Avatar
cclive
A stock Z06 doesn't have a different air intake system. The MAF will sometimes only show a problem when the engine is being pushed hard, so now try doing exactly what started the code before and see what it does...hopefully the cleaning took care of it, but at this point if the code reappears when you are getting on the throttle, then it needs a new MAF
Old May 15, 2016 | 03:06 PM
r2boxers's Avatar
r2boxers
Does not compute
Only modification done to engine. Running great now. Have ordered a new GM MAF to have as a back up if it ever does it again. Yes it was a little oily.
To 2007 Z06 throwing codes
