Transmission stalling
Old May 18, 2016 | 04:29 PM
l7i7o7n's Avatar
l7i7o7n
Default Transmission stalling
I have an 05 c6 and I recently flushed the transmission fluid because it started feeling like it was slipping. I followed all correct flush procedures refilling and also installing a B&M deep transmission pan. I went on a drive ant went about 70mph. Slipping transmission, it's a auto A4 custom built tranny with a 3600 stall. I went and bought a code reader and these are the codes.
U2106-00 /lost comm with Tcm
U2100-00 /can bus comm
C0561-71/system disabled info stored
0281-00/ dynamic rear prop
Does anyone have any suggestions, or ideas. I would greatly appreciate it.
Thanks in advance RON
Old May 18, 2016 | 08:23 PM
CMY SIX's Avatar
CMY SIX
and you wouldn't call the "custom shop" that built it?
Old May 18, 2016 | 08:40 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I agree. Call the shop
Old May 18, 2016 | 11:01 PM
xBoostx's Avatar
xBoostx
Are you sure you have enough fluid in that trannie?
Old May 18, 2016 | 11:36 PM
mch28's Avatar
mch28
Make sure the electrical plug doesn't have any wires pulling out and is seated all the way.
Old May 19, 2016 | 12:28 AM
l7i7o7n's Avatar
l7i7o7n
I called him and he said he never has issues with shifting into overdrive. He told me to take it to a shop near me and keep him posted.
Old May 19, 2016 | 12:33 AM
l7i7o7n's Avatar
l7i7o7n
I checked tranny fluid and all is good. I will check the plug for pulled wires and seating. Thank you for your assistance.
Old Jun 15, 2016 | 08:14 AM
l7i7o7n's Avatar
l7i7o7n
I checked fluids and they are good. I have just the 2100, and 2106 doc codes now. I called the transmission shop and he said the codes aren't what he handles. Can anyone give me some help with these codes or where I can go for fixing this issue?
Old Jun 15, 2016 | 02:02 PM
CMY SIX's Avatar
CMY SIX
really didn't mean for that to sound bone headed but to someone who understand an auto there simple, to someone who does not, it's rocket science
Old Jun 15, 2016 | 02:05 PM
CMY SIX's Avatar
CMY SIX
well everybody's been downing him, but if it was me I would try to get ahold of Chuck Cow. changed the filter too? o rings not pinched installed properly? I know I'm reaching but about all I can think of?
Old Jun 15, 2016 | 05:49 PM
l7i7o7n's Avatar
l7i7o7n
Default Battery corrosion
I removed my battery and I found lots of corrosion under it. I was wondering if there is anything in that area that would cause this issue? I also have a snow methanol pump in the front drivers fender panel. If there was something in that panel that became corroded would it cause this issue? I'm just thinking about any possible issue that may cause a corrosion issue being that methanol is highly corrosive and I have read that a bad ground could cause this issue. Just shooting in the dark. I did check plugs going to transmission, and I also checked the plugs next to the battery on the fire wall.
To Transmission stalling
