Lifter problem
Old May 19, 2016 | 07:47 PM
nenji01's Avatar
nenji01
Default Lifter problem
hey guys i have seen some pretty smart people here who really know their stuff so hopefully one of you can help me out on this
my friends camaro (ls3) has a
Texas Speed Stage 4 LS3 235/239 .627"/.624" 3-Bolt Camshaft
since he bought it roughly 500 miles ago
since then a lifter snapped and he had to replace all lifters and the cam aswell with the same exact cam because it had gotten scratched up
pushrods are 7.400 .80
he then bought new lifters from texas speed and explained his problem to them and asked if maybe the pushrods the car has is putting too much or too little preload on them and they said the pushrods size was correct, however it happened again not even 100 miles after putting everything back togther
oil pressure always was good
oil temperature was fine as well
everything seemed fine until the lifter failed on a different cylinder he reused the same push rods but never tagged the one from the previous cylinder
if anyone can chime in it would be greatly appreciated
Old May 19, 2016 | 08:34 PM
rjacobs's Avatar
rjacobs
Were valve springs inspected? Texas Speed had a bad batch of valve springs at some point(although they wont publicly admit it, there are 2 people locally who got new springs from them due to this bad batch).
And those lifters in the pictures, how long were they out of the motor for before that picture was taken, because those are DRY AS A BONE. Lifters hold a lot of oil. Mine still had oil in them 2 weeks after they came out of the motor.
And push rod length is factory length. If no head milling was done, the length is fine. The factory lifters have a lot of travel in them, like .100 or something like that so they will soak up A LOT of push rod length variance.
Were the lifters re-installed with all the holes facing the same way?
Lifter bores could be trash in the block.
Were the buckets replaced?
How do the bearings in the cam journals look?
Old May 19, 2016 | 09:04 PM
nenji01's Avatar
nenji01
the previous cam was pretty scratched up and kind of scorn in one of the bearings almost as if the lifter was bone dry grinding on it which is the one that snapped on the picture (does lifters have been out for around 20-30 days)
he reused the buckets and cleaned the lifter bores as best as he could with the engine still in the car
my first thought was lack of lubrication aswell but it doesnt explain why only one lifter breaks the current state of the car now the engine has one lifter stuck in the bore doesnt want to come out
maybe the lifter holes wasnt facing the right direction ? he will check it tomorrow he is pretty frustrated lol thanks for that i hadnt think of it
Old May 20, 2016 | 10:07 AM
irok's Avatar
irok
he's got a lot more than a lifter problem.this will take a rebuild to repair
Old May 20, 2016 | 10:39 AM
MyLS1Hauls's Avatar
MyLS1Hauls
All that crap has now gone through the oil pump twice. Motor needs to come out and have everything cleaned and inspected. Oil pump will be trashed. Cut open the oil filter, and you'll find shavings. The stuck lifter needs to be pulled out the bottom. Don't force it out the top.
Lifters usually only do that if they are bouncing against the cam lobe. There is another issue going on that has yet to be discovered.
Old Jun 30, 2016 | 06:34 PM
nenji01's Avatar
nenji01
hey guys anyone know how the lifters hole should be facing to the motor or to the outside?
Old Jun 30, 2016 | 08:00 PM
Unreal's Avatar
Unreal
**** just happens some time.
That being said, bouncing a lifter can cause that, or excessive spring pressure, which I doubt in that case.
Same thing happened to me when I had a shop that didn't know crap spec me a "custom cam" and they picked the most aggressive lobes comp makes.
Old Jul 2, 2016 | 01:45 PM
MyLS1Hauls's Avatar
MyLS1Hauls
It doesn't matter which way the oiling hole faces. It gets oiled the same either way.
What did you guys find when you tore into it?
Old Jul 2, 2016 | 02:14 PM
Pitufina's Avatar
Pitufina
Sounds like valve springs issue or extremely aggressive ramp lobes like Unreal stated. Otherwise, I would look at oil starvation or improper valvetrain geometry although the chances may be small.
I agree the engine needs to come out. I wouldnt trust it at this point.
Old Jul 2, 2016 | 02:23 PM
Unreal's Avatar
Unreal
My motor went on to live a long happy life, and is still running in another z06 (that dropped a valve and took out his motor). I made sure to push the lifter down and out through the bottom, because pulling it up and out like you did can trash the lifter bore/block. So make sure to inspect and get the bore checked out.
Old Jul 2, 2016 | 10:08 PM
nenji01's Avatar
nenji01
The lifter tray seemed to have damaged he didn't noticed amd the lifter seemed to have moved so maybe that was the culprit (similar to unreal's experience) along with the aggressive cam he flushed the engine and cleaned all the mess and its now in the process of going big cam n/a to lsa blower on the ls3 with the lsa cam hopefully there's no more broken lifters
To Lifter problem
