1 7/8 Headers Under $300
Old May 22, 2016 | 06:24 PM
Nick_04k's Avatar
Nick_04k
Default 1 7/8 Headers Under $300
Anybody bought them off eBay? Listed @ $278 and item location says Houston. Ive been watching the seller for awhile and he has sold many sets of these.
Old May 22, 2016 | 11:55 PM
xBoostx's Avatar
xBoostx
There's no question they will make power for the price there's no room for complains only question will be fitment but that's pretty much a question for must corvette headers lol.
Old May 23, 2016 | 08:31 AM
Dano523's Avatar
Dano523
A listing would help, but chances are they are just OBX headers sold under another name instead.
Old May 23, 2016 | 11:15 AM
irok's Avatar
irok
Default not likely
OBX are a great fitting header with beautiful welds and excellent overall quality that make the same power as any header out there.dont hold your breath waiting to find them anytime soon selling for $278.
Old May 24, 2016 | 12:03 AM
buckmeister2's Avatar
buckmeister2
The only similar listing I found wasn't headers...they are just x-pipes and connections. Here is the listing...from houston, similar price...
http://www.ebay.com/itm/Stainless-St...dWqpg~&vxp=mtr
Old May 24, 2016 | 12:34 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I couldn't find them either. I just installed a set of the obx and offroad x. They fit very well
Old May 24, 2016 | 09:22 AM
Dano523's Avatar
Dano523
Would have been cheaper to get the kit with the cat'd X pipe.
Hence the high flow cats only rob you about 3hp, but keeps the car from reeking of un-burnt gas at every stop light instead.
On the postive note, if you got the X pipe with resonators, you can pull the resonator sections to add in high flow cats isntead.
Old May 24, 2016 | 05:16 PM
Bobby95's Avatar
Bobby95
How long did it take you to get your OBX headers? I've had some on order what seems like forever now and they still haven't shipped yet...
Old May 24, 2016 | 09:38 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Where'd you order them from?
Old May 25, 2016 | 01:22 AM
napp e roots's Avatar
napp e roots
Bought ebay set for 320 shipped back in febuary. It's just bent metal not much to screw up. A buddy got the same ones a year ago and had no problems. Headers cat less x pipe and connector pipe for the mufflers
Old May 25, 2016 | 01:44 AM
mvvette97's Avatar
mvvette97
Mine were shipped on a Wed. and had them friday. I'm in iowa and they came from california
Old May 25, 2016 | 01:47 AM
mvvette97's Avatar
mvvette97
Not sure if I will get in trouble for posting this link but here it is. If not allowed then I will remove it. Don't want to cause hard feelings with vendors.
http://www.ebay.com/itm/111784931655?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jun 5, 2016 | 02:43 PM
Nick_04k's Avatar
Nick_04k
The exact seller I was talking about is temporarily out of stock. I have the listing saved in my eBay so I can still see it but a current search for the item won't turn up his listing. I messaged him to see if he will be getting more but haven't received a response yet.
Old Jun 5, 2016 | 04:16 PM
Cherokee Nation's Avatar
Cherokee Nation
Hey guys: Are the OBX headers welded 360 around the outside of the flanges?...Thanks
Old Jun 5, 2016 | 06:02 PM
Dano523's Avatar
Dano523
FYI, on a stock LS-2 and LS-3, your giving up Lower end power with a 1 7/8" ID header.
You want 1 3/4" ID headers for these two oem motors, which gives a better Bernoulli effect at the lower engine RPM's, yet flow fine for max RPM's as well. Hence bigger ID headers are not better if too large for the motor, since the larger ID takes more exhaust volume to build up the needed gas speed to create the Bernoulli effect/ vacuum effect of the collector to draw out the gasses in the header tube.
So a good header design and piping ID size is get the header to Bernoulli effect at the lowest speed possible, but not to create a volume block point with too small of piping at top RPM's instead.
Old Jun 5, 2016 | 06:09 PM
Nick_04k's Avatar
Nick_04k
Very well covered topic. Tons of dyno comparisons on the internet. Going to be very small differences in the tq at low rpm. However probably 75% of members that add an ORH will not stop with the mods there.
Old Jun 5, 2016 | 09:11 PM
irok's Avatar
irok
yes primary tubes to flange
Old Jun 5, 2016 | 10:02 PM
Suns_PSD's Avatar
Suns_PSD
https://youtu.be/NekTRPx68zs
Incorrect. All stock head ls2's need 1 3/4" headers where as the LS3 does better with the 1 7/8" inch headers with any level of modifications.
Old Jun 7, 2016 | 11:17 AM
irok's Avatar
irok
my stock headed LS2 with 1 7/8" OBX catted LT's made 650 rwhp.the 1 7/8" didn't seem to hinder rwhp output much
To 1 7/8 Headers Under $300
