Help! A4 30 spline output shaft
Old Jun 6, 2016 | 03:28 PM
rsigue's Avatar
rsigue
Default Help! A4 30 spline output shaft
Does anyone know where I can purchase a 30 spline output shaft for my 2005 c6 base with the 4l65e transmission.... Im installing a 08 z06 differential an this is one of the items that I need.......Any help is welcome...........
Old Jun 6, 2016 | 11:10 PM
irok's Avatar
irok
Default this
just did the same in mine.had RPM Transmission build a level VI 4L65E with 30 spline output shaft and spacer for the new 08 Z06 differential.the spacer-adapter plate was around $550.dont know if they will sell you the output shaft without purchasing transmission from them.the output shaft was not a very expensive option when having the trans built.Rossler wanted about $650. for the shaft last I saw.
Old Jun 8, 2016 | 08:36 AM
rsigue's Avatar
rsigue
Yes thanks , these output shafts are only available at rpm , and the plate also,,,,, no one else makes this kit.. So don't waste your time surfing the net. I tried over 20 companys and no one has it..... its expensive so get ready to spend 1200.00
Old Jun 8, 2016 | 05:04 PM
dennis50nj's Avatar
dennis50nj
$1200.00 well spent to bullet proof
To Help! A4 30 spline output shaft
