PCV Catch Can Routing Question...
So, I pulled my TB off yesterday and noticed I had fresh oil puddled on the Throttle body blade opening, Buddy seen this and said they way they did it was wrong and It needs to breath so I dont blow my rear main seal because All I am doing is taking everything and just putting it back through my intake.
So my question is, If I go back and plug the holes on my airbridge, Cap the 2 nipples on my valve covers and scrap those 2 hoses. Pick up a oil cap with a -10 nipple and run that into my breather catch can and hook that up between the PCV and intake. Would this be sufficient or am I going to cause a Leak.
Or should I leave a normal oil cap on, Plug the holes that were drilled into my airbridge and take the 2 hoses from my valve cover and put those into the breather catch can and cap the Intake port and PCV nipple basically eliminating the pcv ...
Any help would be appreciated, I just want to stop the oil, Vent everything properly without having a air leak ect....
Crap pic but this was with the catch/can breather setup before when I had a LS6 valley, Claimed PCV Vac leak
What It Looks Like Now
this is what i have always done on all my turbo cars and what i have seen done on every car making serious power just run -10 lines to a catch can with a breather for the engine to breath and any blowby oil get trapped there and dont make a mess on ur bay, if u have a lot of build up pressure going on u might need a big catch can with multiple breathers
Catch can should go between valley cover and throttle body, no reason NOT to run one.
ETA: Do NOT cap the valley and intake manifold...put your catch can there.
You can go as simple or crazy as you want with catch cans, etc. honestly.
Are you seeing much oil in your intake now?
I'm running mine the way A&A does theirs.. basically added one way valve to hose from valley cover to post-TB (to stop boost from going into the crank case), then hose from passenger valve cover to air filter. Serves as fresh air in when not in boost, and blowby will vent there while in boost. I haven't had any issues with it. Had MM can setup but started getting smells again so I got rid of it.
I'll sell it cheap if you want it.
