Bad Coolant Temp sensor?
Old Jun 16, 2016 | 04:15 PM
bruttix's Avatar
bruttix
Default Bad Coolant Temp sensor?
Hello firstly off i have a 2006 c6 stock red vette, and here recently sort of suddenly i would occasionally look to the left gauge and see my engine temperature be abnormally high like 230 or 240 and this happened in stop and go traffic so i didnt think too much about it. After traffic broke loose it was normal temps.Then today i left my car on and ran inside and came outside and a "CHECK COOLANT LEVELS" message came up and the temperature was at like 235+......
So i let the car sit and checked my coolant levels and it wasn't that low at all but i refilled the coolant to where it should be and then burped the car. Then next day i drove it around and then the temperature started climbing really high again like 240+ going at like 30mph. So everytime it got that high i would pull over and wait. BUT a tricky thing is after i wait 30seconds i turn the car on to look at the temperature dial and display and it says 200 (normal temp for my car)
how in the hell did it go from 240 to 200 in less than a minute after turning it off?
also.... no leaks or loose lines i checked. maybe still air in the lines?
Old Jun 16, 2016 | 04:27 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'd be looking at fan connector first. They are known to melt which obviously causes issues.
Old Jun 16, 2016 | 04:36 PM
extrapilot's Avatar
extrapilot
What he said^^^^^^^^^^^^^^ and check for debris in front of the radiator, make sure the fines are clear...
Old Jun 16, 2016 | 04:38 PM
bruttix's Avatar
bruttix
Well when the car reads that high temperature i can hear the bigger highspeed fan kick on. Is that the fan ur referring too?
bruttix's Avatar
bruttix
i checked the front. all is clear and no holes. nothing.
Old Jun 16, 2016 | 04:56 PM
extrapilot's Avatar
extrapilot
If there is positively no air in the system, it possible that the coolant sensor is going bad.
Less likely a water pump but that's not a fore sure thing also.
The sensor is cheap enough to get replaced, but I would definitively get one from the car dealer, as some off brands of electronics are sometimes problematic.
How many miles are on the car?
Old Jun 16, 2016 | 04:57 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Sensors are cheap, not a big deal to just replace to be sure. It's on the driver side cylinder head, near the alternator.
Old Jun 16, 2016 | 05:03 PM
bruttix's Avatar
bruttix
how much is the sensor and perhaps do u have a image showing where this sensor is located?
bruttix's Avatar
bruttix
85k miles 2006 vette
Old Jun 16, 2016 | 05:06 PM
extrapilot's Avatar
extrapilot
Here you go..
Old Jun 16, 2016 | 05:08 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
AC delco is $10 on Amazon. Gm ones are more I'm sure
It's behind alternator almost but you can see it in the pics posted
Old Jun 16, 2016 | 05:09 PM
extrapilot's Avatar
extrapilot
Only other issue is that I haven't seen posted but a possibility is clogging of the radiator core. Is the coolant fluid bright in color, should be using the "pink" stuff?
Old Jun 16, 2016 | 05:16 PM
bruttix's Avatar
bruttix
yeah my coolant color is clear and bright green from "Peak" coolant how would i know if their's a clog
Old Jun 16, 2016 | 05:29 PM
bruttix's Avatar
bruttix
Here you go..
ahh yeah i located it what am i looking for? i dont see anything visually wrong
Old Jun 16, 2016 | 05:42 PM
extrapilot's Avatar
extrapilot
You won't....just have to try it as it is reading still OK but maybe not that accurate anymore.
Old Jun 16, 2016 | 05:44 PM
extrapilot's Avatar
extrapilot
Using a Laser Infrared Temperature Gun, while the engine is running, it could be used to check the temps at each core row, as a blockage would be indicated by a lower temp than a core right next to it. I would think this to be tricky to do since there not much cores very visible. Other than that, a specialty radiator shop could help you out there. I think a clog is a very long shot here, since you stated the fluid is clear and brightly colored.
Old Jun 16, 2016 | 05:52 PM
bruttix's Avatar
bruttix
okay. and another question what do you personally do when u yourself are burping ur car?
To Bad Coolant Temp sensor?
Old Jun 16, 2016 | 06:03 PM
extrapilot's Avatar
extrapilot
I have always just ran the engine at idle until I feel that the thermostat has opened and added coolant slowly keeping the coolant tank cap off, watching for bubbles to come up. Once I see no more bubbles I would setup a fast idle so that coolant would get drawn from the tank for a few minutes, then close it up.
Old Jun 16, 2016 | 07:25 PM
bruttix's Avatar
bruttix
Bubbles are coming up but once it gets hot it starts squirting out coolant
Old Jun 16, 2016 | 09:17 PM
Dano523's Avatar
Dano523
Here your problem and you have a mix of green radiator fluid and Dex-cool (orange) in the motor and it has caused clumping/sludge'g problems when the two tried to mix in the system.
So your going to need to have a professional flush to get the sludge out of the system.
Hence something like super flushes to start with with the T stat removed, then distilled water flushes to get the last of the super flush out, then T stat replaced with a new one and the system refilled once clean with 50/50 Dex-cool.
And since the old mixed radiator fluids and flushing agent need to be reclaimed, this is not a project to just do out in drive way.
