M6 Shifter ball replacement
Old Jun 21, 2016 | 05:06 PM
chrismcdaniel's Avatar
chrismcdaniel
Default M6 Shifter ball replacement
SO, I now know how to remove the stock shifter, but since its doesn't have a threaded shaft, I cant put my aftermarket Hurst Handle on it. Is there a replacement shaft I can buy or is the stock shaft able to be threaded? What is the normal fix.. I don't want one of the little cue ball shifters.
Old Jun 22, 2016 | 06:29 PM
Russkier's Avatar
Russkier
You may need to install a MGW or similar shifter that has a threaded shaft. They have a model that fits the threads of a C-5 which are threaded. I recently made the change and found that the Hurst shift **** is not made in the thread size that is needed, so I had to tap the threads in the **** to match the shifters threads. It was not hard, just a p.i.t.a.
Old Jun 22, 2016 | 07:11 PM
chrismcdaniel
Thanks for the reply. I'm starting to see that it's just a PITA
Old Jun 22, 2016 | 08:41 PM
CMY SIX's Avatar
CMY SIX
google is your friend, if I remember this has been discussed MANY times before
Old Jun 22, 2016 | 09:28 PM
chrismcdaniel
Thanks Devil dog
To M6 Shifter ball replacement
