CV axle boot Replacment
Old Jun 22, 2016 | 05:28 PM
ez2spd's Avatar
ez2spd
Default CV axle boot Replacment
Who has done this on their C6z?
Just ordered new boots from the dealer, axles have 18k miles and driver inner, pass outter have small enough holes that grease went everywhere!
Luckily caught it early on.
Found a few threads back in 2006/2007 but the links no longer worked..
Thanks!
Old Jun 22, 2016 | 07:01 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I had one develop a hole a few years ago. We replaced it with an aftermarket silicone boot which they install with a special tool that expands it enough to fit over the joint without taking it apart. Haven't had an issue since so I guess they are good replacements. I would assume to install a stock one the joint would have to come apart.
Old Jun 24, 2016 | 07:17 PM
ez2spd's Avatar
ez2spd
Figured I would update this post!
It's rare that someone starts a post now a days with a problems and comes back with a WORKING solution or update!
The CV boot was a VERY simply project, removing entire CV took me just under 15 min, disassemble CV took 5 min, new boots installed in under 10 min " cleaning all the grease was the most time consuming portion " reinstall in 20 min and were good to go again!
If anyone has questions I'll gladly walk you through what I did.
Remove CV ( directions are all over the place )
Cut the metal ties off the boot, be prepared to clean a mess!
CV pulls apart once boot is off, simply reinstall new book after removing snap ring, pour the grease into the CV and apply boot back!
Old Jun 25, 2016 | 08:07 PM
KM177122's Avatar
KM177122
Nice work!
Old Jun 25, 2016 | 08:29 PM
ez2spd's Avatar
ez2spd
Thanks!
Only issue all day has been locating CV clamps! They are a pain to find a proper set that actually work!
Dealer shows them in system but no longer available
Old Jun 26, 2016 | 10:42 PM
KM177122's Avatar
KM177122
Thanks!
If you don't mind me asking, where did you find a good pair of CV clamps at?
Old Jun 26, 2016 | 11:25 PM
ez2spd's Avatar
ez2spd
Have yet to find them! Axles sitting here on my table till tomorrow when I can make calls! Bound to find a set! Super glue and duct tape here we come! ��
Old Jun 27, 2016 | 04:47 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Available at any decent parts place. Summit, Orielys, etc. Dorman has clamp kits too.
Old Jun 27, 2016 | 07:04 AM
KM177122's Avatar
KM177122
Ha! Best of luck!
Old Jun 27, 2016 | 10:05 AM
Unreal's Avatar
Unreal
IMO, swapping on a set of c5 axles if it isa 2006/2007 z06 is a far better investment as they are much stronger axles.
Old Jun 27, 2016 | 10:33 AM
ez2spd's Avatar
ez2spd
I went with 07 axle off 10k mile z06 and just replaced the boots after inspecting internals
Old Jun 27, 2016 | 02:20 PM
Unreal's Avatar
Unreal
06-07 axles are the weakest axles made and snap easily. Best of luck, but money should have been spent on swapping to a stronger axle if you had to replace a boot or axle.
Old Jun 27, 2016 | 04:37 PM
ez2spd's Avatar
ez2spd
To CV axle boot Replacment
