Help! Ballast
Old Jul 2, 2016 | 12:58 PM
Tom1ove's Avatar
Tom1ove
4th Gear
Default Help! Ballast
Took my car to the stealership to get my low beam light changed due to driver side light was out. I was told the light is not out. It's the ballast that need to be replaced. Was told the part is $400 bucks and labor is $300 bucks. Started to get it done, but thought I'd do a lil research before I pay. It's a 2007 base corvette. From my readings I'm wondering do I have to take of the front bumper or can I replace it from the wheel well? Is this something I can do myself???? Help.
Old Jul 2, 2016 | 03:33 PM
RicK T's Avatar
RicK T
Yes, you should be able to do it yourself.
Read this entire thread for all of the tips:
https://www.corvetteforum.com/forums...ange-help.html
Old Jul 4, 2016 | 01:59 AM
db2xpert's Avatar
db2xpert
There is a recall on 2007 headlights.
Don't remember if it's this exact problem, but wouldn't trust a high dollar dealer diagnosis...
Old Jul 5, 2016 | 01:45 AM
Grimlock13's Avatar
Grimlock13
Recall involves fusebox problems with heat cycling the contacts don't touch good enough. All they do is put a jumper wire to bypass.
Not going to be his problem if only one is not working.
To Help! Ballast
