pjg107
Old Jul 6, 2016 | 10:02 PM
pjg107's Avatar
pjg107
3rd Gear
Default pjg107
Have an '06 that will not start. Tried to enter the car the other day and the door would not open. Changed battery in the fob, still nothing. After getting into the car, it would not start. No click, grunt, nothing. Took car battery to shop. They said battery was low. Car acts like there was no fob present. Any suggestions?
Old Jul 7, 2016 | 08:17 AM
BlindSpot's Avatar
BlindSpot
You should get lots of replies here to replace the car battery, and I echo that. The electrical systems on CAN configured cars require a threshold voltage, around 11.8v. at that threshold and below, nothing works normally.
Old Jul 7, 2016 | 11:53 AM
extrapilot's Avatar
extrapilot
And with this heat of summer, batteries are known to croak...
Old Jul 7, 2016 | 11:22 PM
pjg107's Avatar
pjg107
3rd Gear
Hoping to install new battery tomorrow and it will work.
Old Jul 8, 2016 | 03:09 AM
Dano523's Avatar
Dano523
Depending on the problem, could be something in the charging system wire connection points, and the reason that the battery is not being recharged/why a new battery may have the same problems after a few days as well.
Also, good habit to put the car on a battery tender if your not going to drive it for a few days.
To pjg107
