MAF sensor
Old Jul 16, 2016 | 06:11 AM
daveholl's Avatar
daveholl
Default MAF sensor
Had a CEL and code P0171 on my '05. Finally got up the nerve to remove the air filter assembly and look at the MAF sensor. The screen was off- color and dirty, so I cleaned it with the proper stuff, and reassembled. Disconnected the battery for awhile, and so far, no more CEL.
Just wanted to relate this little success.
Dave
Old Jul 16, 2016 | 01:41 PM
glimmer's Avatar
glimmer
2nd Gear
If I am not mistaken. ..the code you received is for a lean condition. Check injectors for seal leaks with a spray bottle of soapy water. bubbles and or engine hesitation indicate oring seal leak and that you are getting unmeasured air flow to the cylinder creating a lean condition.
