I have 08 corvette with headers and edelbrock super charger , no cam. Rest of car is stock. Dino at 520 hp at the wheels. Took car to track and had to use traction control to take off when car shifted into second wheel spin like on ice. Car has stock 19" wheels with Michelin tires... Will drag radials fix this , which ones do I buy, and which ones work best with out heating them up... Thanks any help apreciated..
No it doesn't , just not wanting to waste money on rear wheels if I will have same problem, then would wonder if I bought wrong tires... Thanks again for input...
I've just learned to be a better driver and ease into the throttle. If I give it full gas I can spin the tires in third on DRs sometimes. Mine are only 555R's though, they make stickier tires for sure.
1. Install street drag radials and be very cautious on of wet roads.
2. Install the widest stickiest street tires and use your foot to manage
the power.
I too have S/C 08 but with an A&A Centri kit. I installed wider rims to accommodate Michelin Super Sport 265/35/18 fr. and 305/30/19 rr. tires. Traction improved, but I still have to manage traction with my foot. Also, a Centri S/C is a bit more manageable at lower rpm.
first is it a stick or auto car? i make north of 750 whp and i am just running a hoosire drag radels and i had no issuses with hooking on the track or the streets being a stick car .iv turned off all my traction functions in the ecm to avoid it coming on an slowing the car down
