Bolt ons!!!!!!
Old 07-28-2016, 11:20 PM
Nelson305
3rd Gear
Nelson305's Avatar
Default Bolt ons!!!!!!
Hey guys im a newbie and want to go full bult-ons, whats going to give me the highest hp/tq
Chevy corvette 2008 ls3 stock soon to be modded!!! 😈
Old 07-28-2016, 11:37 PM
russ472
Support Corvetteforum!
russ472's Avatar
supercharger is the way to go
Nelson305 (07-28-2016)
Old 07-28-2016, 11:43 PM
Nelson305
3rd Gear
Nelson305's Avatar
Lol i know but id rather go full bolt ons for now, thanks tho!!
Old 07-28-2016, 11:55 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
The first question is what do you intend to do with the car? The second is A6 or M6?
Old 07-29-2016, 12:00 AM
Nelson305
3rd Gear
Nelson305's Avatar
Just want to do some really hardcore spirited driving and take it to the track 1/4 mile....its manual c6 ls3 2008
Old 07-29-2016, 05:30 AM
advancivic
advancivic's Avatar
Heads,cam,headers,exhaust,intake,ported intake manifold, ported throttle body with fuel upgrade to run e85 making 500-550whp will cost as much as a ecs supercharger and you'll be making similar power.
However imo from personal experience a xxx whp n/a car vs the same xxx whp boosted car the n/a car will be quicker from a dig and most likely 1/4. But from a roll the boosted cars normally do better and could come around the n/a in the top end of the 1/4.
It's really what you gotta decide is what's your goal. Will you be happy with less then 600 hp or will you want 600-1000hp? Cause with the s/c you can grow and make more power
N/a you'll be pretty tap out around the 500-600 mark unless you go nitrous but then it's w/e
Old 07-29-2016, 06:22 AM
Dcasole
Dcasole's Avatar
Received 2,241 Likes on 1,634 Posts
CAI, headers and a Tune will get you into the low 12 second bracket and you will still have a very streetable combination, like the others have said the next step is cam , and then heads and a new intake . The car will still be streetable (depending on how radical of a cam you pick)
From here it all depends on how far you want to go and how much money you have to spend........
Old 07-29-2016, 08:37 AM
jesse82nc
jesse82nc's Avatar
I'm at 540 rwhp/510 rwtq all motor, no supercharger, no nitrous, no turbo, stock heads even. Pretty sure I did some Trick Flow heads I could be at least 575 rwhp.
Mine is a 2009 LS3 M6.
The following 2 users liked this post by jesse82nc:
djjmk1 (08-20-2022), madmatt9471 (07-29-2016)
Old 07-29-2016, 09:06 AM
sevinn
sevinn's Avatar
St. Jude Donor '14, '16
I never liked the term full boltons.
Biggest bang for your buck will be a set of headers, then get your intake manifold ported (I recommend BER), and finally maybe some gears. Don't get a cai on your ls3 unless you just want one for looks. Do a search for "free air mod" here on the forum.
A vitesse controller is nice to have too, but doesn't add any power.
Old 07-29-2016, 09:22 AM
emoFTW
emoFTW's Avatar
Cold air intake, a set of longtube headers, axle back mufflers and a tune. It will keep you happy for awhile and really wake the car up.
Old 07-29-2016, 12:00 PM
legalins
legalins's Avatar
What have you done to get those #'s?
Old 07-29-2016, 12:14 PM
Silverado777
Silverado777's Avatar
A 418 CI stroked motor isn't exactly "bolt on".....
rpmextra (07-31-2016)
Old 07-29-2016, 12:18 PM
sevinn
sevinn's Avatar
Just about everything bolts on
Old 07-29-2016, 02:38 PM
jashmore1234
jashmore1234's Avatar
This. A SC vette drives like a normal car until you stick your foot in it, then it becomes a different car. Picture this:
I tell people it is just a bolt on car, since I just bolted on the supercharger, headers, exhaust, injectors, intercooler, damper, etc., technically I'm not lying.
Gering (08-02-2016)
Old 07-29-2016, 03:09 PM
mattdracing
mattdracing's Avatar
Just do a nice set of headers (American Racing or kooks in my personal opinion), cold air intake, and a tune. That will be your biggest bang for the buck and won't break the bank at all. If you decide you want more power after that then you can do a cam, valve springs, pushrods, etc. Headers, CAI, tune will put you roughly around 420whp if I remember right. A decent sized cam will put you 470-480whp. Those are all the bang for the buck N/A mods if you're wanting to stay all motor
Old 07-29-2016, 03:14 PM
Dcasole
Dcasole's Avatar
Old 07-29-2016, 03:26 PM
russ472
russ472's Avatar
if you want the highest hp/tq that is bolt on..... seems to be the definition of forced induction.
How much "bolt on" can it get?
To Bolt ons!!!!!!
Old 07-30-2016, 11:37 AM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Okay let's go with Bolt On's for your Vette - starting from the front to the rear:
(1) CAI - (VARARARM, Halltech, K&N etc.)
(2) Plugs (NGK, etc.) and Wires 8mm (MSD, Taylor, etc.)
(3) Ported and Polished Throttle Body (Optional)
(4) FAST or Ported LS3 Manifold (Optional)
(5) Trunion Upgrade for Rockers
(6) Could do 1.8 Roller Rockers (must get the LS3 rockers) "BUT" you will need to change the valve springs as well due to the higher lift (coil bind)
(5) Long Tube Headers, Hi-flow Cats, Xpipe into factory Bi-Mode Mufflers or mufflers of your choice (B&B, Corsa, etc) "OR"
(7) ZR1/Z06 exhaust manifolds with the 3" factory cats and X-pipe into your factory Bi-Mode mufflers or mufflers of your choice (B&B, Corsa, etc.)
(8) Z06 Clutch Kit or Clutch Kit of your choice when needed or ready
(9) Rear end gear change 3.73 or 4.10 from your current 3.42
There you have it - you should have no problem reaching into the solid 11's like many others with just bolt on's -
Thanks,Matt
The following 2 users liked this post by madmatt9471:
Alkandary00 (12-16-2020), Born (03-10-2022)
Old 07-31-2016, 02:39 AM
HOXXOH
HOXXOH's Avatar
Thanks,Matt
Certainly a workable list. I'll follow your choices with what I ran to run high 10's a few years ago.
(1) Vararam
(2) Stock OEM
(3) ported TB
(4) ported IM
(5) n/a
(6) n/a
(7) Z06 exhaust manifolds w/gutted cats into Z06 mufflers
(8) 3600 stall Yank converter for A6
(9) 2.56 gear
(10) race tweaked tune (initially requires a good tune, then buying HP Tuners software and learning how to mod it based on timeslip results and track conditions)
(11) 275/40 x 17 Hoosier DR (track only)
Old 07-31-2016, 07:06 AM
Mike050788
Mike050788's Avatar
Quick Reply: Bolt ons!!!!!!
