SRS light flashing - no fault Code
Corvette 2008 coupé
I have a tough problem, my airbag light is flashing but the Tech II shows no fault codes.
The only code that exists is B2376 Driver Position module / Drivers seat assembly horizontal sensor range / performance.
Hope someone has an idea where my techniques never had this problem before
Best bet, the air bag module connector under the drivers seat has come loose and not the best of connections
If you want fix is yourself, its not hard (have to pull the seat to get at it), but GM issued a TSB for the problem (should have gotten the letter), and they will fix it if you wish isntead (hence install the zip tie so when you move the seat, the connector harness do not drag on the carpet to slightly disconnect the connector isntead).
