Anyone running a LPE converter box? Curious how reliable they are? I'm dropping an LS3 in my C5Z and was planning to run one so I don't have to pull the motor apart and change the reluctor wheel.
I ran one. Hated it. It kept losing signal around 5500rpms. I ended up having to pull the crank and swap reluctors.
Yeah is there any other options. I remember the guys at efi connection had some great wiring solutions. Maybe there will be others that will chime in with other options/opinions. Possibly the guy above got a bad one.
I don't think there the any other options out there
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Been there, done that - save yourself the aggravation and do it right while the motor is out.
I did an LS7 swap for a friend's 2005 a few years back and the idiot at the machine shop knew he was supposed to change the reluctor wheel but forgot and I ended up not discovering this until after the motor was installed and I couldn't figure out why it wouldn't fire up.
We tried using the Lingenfelter box and it ended up being SOOOO unreliable that I had to pull the motor to have the proper reluctor wheel installed.
Were you using the newer version that has a separate power source to the box? Seems the first version had overheating issues due to how the box was powered which would cause it to shut off. I certainly don't want it doing that all the time.
There was only one version of the box at the time I tried using it.
