opinions on clutches...
Mantic dual or triple
RXT is you measure/shim and luck out with a good one
RPS carbon if you measuer/shim
Some people are having decent luck with monster, but never messed with them.
Same thing I tell everyone wanting a 1000hp vette. Don't do it.
thought about RPS and cleod clutches but havent heard much about them.. definitely kicking ACT and Exedy out of the equation now lol
The amount that the clutch will hold, and if you need to strip or DD the car, how well will the clutch allow initial slipping/street drive-abliity.
Hence with some clutches, then hold very well, but are like on/off switches that do not allow much slipping before they bite and grab, or noisy as hell when you have the clutch pedal pushed in instead.
And with any aftermarket clutch, don't treat is like it going to install plug and play!!!! Before you install the torque tube, measure from the back of the bell housing to the face of the fingers, them compress the TB and measure for its face back to the face of the torque tube (area that is going to make up with the face of the bell housing. Now take this amount of free play between the two, and confirm that it in spec with the clutch manufacturers numbers.
As for clutch, kind of a fan of the center force Dyad. It feels like the stock clutch in regards to pedal pressure and being able to slip it, has good holding power, and when set up correctly, has no noise when you are holding the clutch in.
The down fall, like any clutch that is set up to allow slipping, it not going to last as long as a stick and grab type racing clutch when you are abusing it over and over again instead.
I researched a lot before I swapped clutches years ago. To the point where I was giving myself a headache and was almost to the point where I was going to put all of the names in a hat and just pick one. I spoke with my shop at the time and based on my power, intended use of the car, and budget, they made a recommendations of a Spec3+ w/lightweight pressure plate and flywheel. I have no complaints but am I recommending this clutch to you? No Way. Because your build is vastly different than mine. My suggestion is to ask over in the FI section, since I assume that is how you plan on making 1000rwhp. See what the triple digit power cars are running, what type of driving/racing they're doing, and if they could do it over again would they choose the same clutch. A test drive would be best if you can find an offer. Don't jump into this decision because the clutch is the main link to your enjoyment of the car.
My center force Dyad drives very close to stock. I did add a .125 shim to slave.
Give us a shout if you have any questions.(817-750-2000)
