Rear Axle replacement
Old Sep 4, 2016 | 07:06 PM
  #41
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Well after putting everything back together and changing the gear oil it's been a week and the noise is still gone, Very Strange this Corvette.
Old Sep 4, 2016 | 09:01 PM
  #42
timd38's Avatar
timd38
What aluminum cleaner did you use?
Old Sep 5, 2016 | 12:17 PM
  #43
ls1121's Avatar
ls1121
This....spray on and wash off, you can scrub it but ys must remove it in 30 seconds.
Old May 1, 2020 | 08:39 PM
  #44
Dirk Miller's Avatar
Dirk Miller
PM sent
Old May 2, 2020 | 08:26 PM
  #45
jonjoy's Avatar
jonjoy
Originally Posted by ls1121
HK thanx for the video.
I've been reading for over an hour now and it seems that I can use C5 axle shafts in my 08 Z51, am I getting this right because I see rebuilt shafts on ebay for like $120 each and new C6 shafts are like $500 each, a hard pill to swallow.
That's C5 ZO6 axels those are the ones you want if you can get them, I just scored a set for $150
Old May 3, 2020 | 09:53 AM
  #46
irok's Avatar
irok
The C5 Z06 axle's are no different than axle's from any C5.They are a 5 bearing axle and seem to be much stronger than earlier 3 bearing C6 axles
