Installing new wheel housings
My questions are:
1) Should I take the car to a frame shop to check and possibly fix any frame damage, i don't think there is any damage to the frame but if I attach the wheel house they can pull the frame if need be, correct?
2) What is the preferred order of operation install the new wheel house? Do I install the hood first, then epoxy the new wheel house to the frame?
Right now I have everything on the front end off and I have ground away the majority of the old epoxy to make way for the new epoxy. I say majority because i left a small amount in each factory area so that the spacing will be the same as before when I clamp it all down.
I would have the frame measured at a shop as I read your post you imply this collision was "big".
And measured before installing the wheelhouse.
Seems to me that any frame straightening would be easier with the w/h not installed.
I have no comment for your second question about install order.
Good luck.
