Air conditioner problem
Old Sep 5, 2016 | 12:20 PM
Rickm6's Avatar
Rickm6
Default Air conditioner problem
I have a 2013 Grand Sport that has an intermittent air conditioner problem. I always leave the climate control in "auto" mode set to a fairly low temp, like 65. When I get in the car (its been 90 or higher outside everyday) the air conditioner won't come on unless I turn the climate control off and on again. This occurs about 80 percent of the time. Has anyone had this problem? Thanks in advance! Rick
Old Sep 5, 2016 | 11:26 PM
Cherokee Nation's Avatar
Cherokee Nation
My 08 has the same problem, has been doing it for a couple of years. If I don't use the Auto mode it comes on maybe 70% of the time??...I.ve read on this forum that it is the HVAC unit $$$$$.
Old Sep 11, 2016 | 01:11 PM
Rickm6's Avatar
Rickm6
Thanks Cherokee. I drove up to the lake yesterday and I noticed that I'm unable to make the air come out anywhere but the upper vents. I can't switch the air to the floor for example. Have you noticed your car doing that as well? Thanks.
Old Sep 11, 2016 | 01:28 PM
RicK T's Avatar
RicK T
That "usually" indicates bad mode curtain actuators, but......with your other stated issue I think your best bet would be take it to a dealer and have the HVAC codes checked with a Tech II. I say dealer and a Tech II because most consumer grade scanners don't read HVAC codes.
Anyway, I think you may have at least an HVAC head unit issue and possibly a mode curtain issue also but you have to narrow it down, hopefully with the trouble codes.
Old Sep 11, 2016 | 05:39 PM
truckplay's Avatar
truckplay
has the car had a dead battery recently? sometimes resynching the mode doors will fix it. if it works at all i would try that or have them synched at the dealer but usually can be done in 5 minutes at home without any tools.
To Air conditioner problem
