Tough time refilling coolant
Old Sep 5, 2016 | 01:57 PM
speedz06's Avatar
speedz06
Default Tough time refilling coolant
The first time I installed the dewitts radiator it went "ok" with a quick shot to about 250 and then the coolant went into the motor and all was good to top off.
Now....the coolant wont go in and the engine is nearly overheating before I shut it down.
Following the GM factory manual closely for refil proceedure.
Any suggestions?
Old Sep 5, 2016 | 02:31 PM
jft69z's Avatar
jft69z
Happened to me before. Since then I vacuum fill them with an 'Airlift' system. No more problems.
https://www.amazon.com/UView-550000-...47VTXGMF7SHNM5
(Just an example, you may find better prices elsewhere)
Old Sep 5, 2016 | 02:57 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Pull the small hose that runs to the reservoir tank. Apply a little vacuum, coolant level in the tank should start dropping fast. That has always gotten the air out of the system on everyone I've tried it on when needed.
Vacuuming the whole system is def. a better way to do it but you'll need what ^ posted to do it.
Old Sep 5, 2016 | 04:15 PM
speedz06's Avatar
speedz06
Thanks guys im giving it another shot replaced thermostat even though I know thats likely not it. Vacuum aitlift tool is the way to go from now on.
Old Sep 5, 2016 | 04:20 PM
speedz06's Avatar
speedz06
hey! It worked I had to improvise with a ryobi cordless inflate/deflate tool but got it to draw on the small tube and the fluid went down just as you said.
Now I know......
Old Sep 5, 2016 | 04:22 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Might could use a shop vac or something to try sucking on that hose to get some air/water moving
Old Sep 5, 2016 | 04:43 PM
jft69z's Avatar
jft69z
If you do get this, a little tip. Make sure the 'feed' hose that goes into your coolant source (jug, bucket, etc) is full first before trying to fill the vehicle system. This will eliminate air from entering the engine.
Old Sep 5, 2016 | 08:32 PM
Scooter70's Avatar
Scooter70
Another trick is to unbolt the expansion tank and lift it up/tilt it.
Old Sep 5, 2016 | 08:42 PM
timd38's Avatar
timd38
I have vacuum fill tool, works every time!
To Tough time refilling coolant
