Overheating problem... please chime in!
This morning I had the chance to drive, no ac and a path w no red lights of course, to PepBoys, and had the CEL codes pulled:
P0480 Cooling Malfunction
P1258 Engine Coolant overtemperature
P0480 Cooling Fan 1 control circuit
A few weeks ago my driver's side DRL stopped working, so I thought that there would be a fuse that share that fuction and the radiator fans, but that doesn't seem to be the case.
With that said, I was wondering if you guys could help me with the issue. Where should I begin looking?
Could it be the 60amp fuse at location 25? Any other fuses to check? Maybe the DRL situation has something to do with it?
Could it be the fan relay? I read that if the car is tuned and they tune the fans to be on at all times, the relay can melt due to the heat, and you can just bypass that and hard wire around it.
THANK YOU
I bought some 10gauge cable and 10-12gauge crimp connectors with built in shrink wrap (The car is at the building garage, don't have power access to use my have a soldering gun), and I will hard-wire it.
Should I hard-wire the other 2 cables as well or just that one?
Pics:
Male connector
Female Connector
I'll hard-wire both tonight to my wife's joy, as I had to steal her car today, and she Ubered to work due to the different distances and my need to use a car throughout the day
I will get it done as I had to crimp the wires since my soldering gun didn't reach where the car was (building parking lot), and I don't like the idea of having something that is not as permanent as a soldering job.
Car is working fine though, so thanks for the input
Car mid surgery
I design and currently work on medical devices for electrosurgery, and all electrical connections are crimped. These are parts used in ER and emergency situations for life saving, and for heart and general surgery. Crimps work amazingly well, and better than solder in a lot of cases.
The 10 gauge wires were pretty hard to crimp, so I just didn't feel as confident as a 14 gauge wire being crimped to a half pancake style. I feel like if I pulled on the 10 gauge crimp hard enough it would come apart.
Also the ground wire was pretty stretched out, I would hate to have that disconnect with time, since what was reinforced by 2 10-gauge wires holding on for dear life lol
Some have made a wash wand from a piece of copper pipe attached to a garden hose and form a right angle at the tip.
https://www.corvetteforum.com/forums...stock-fan.html
