Need Help ! Fast Fuel Rails
Old Sep 9, 2016 | 12:32 PM
OregelLs2's Avatar
OregelLs2
8th Gear
Default Need Help ! Fast Fuel Rails
Hello, Need some help. How do I feed the fast fuel rails. Theres no space in the back of the fuel rail to feed it. I also can connect it in the front because thats where the adapter to my fuel selenoid is going for nitrous along with the cross over line. Is there a special fitting I need? To feed it from the back.
Thanks.
Old Sep 9, 2016 | 12:36 PM
timd38's Avatar
timd38
You should be able to feed from the front or back. I used Holley rails, almost identical and I did from the rear. Not sure if you can see it in this picture clearly or not. If you look between the brake booster and the booster line, I did 180 with fittings to go into the factory line on the firewall.
Old Sep 9, 2016 | 01:00 PM
OregelLs2's Avatar
OregelLs2
8th Gear
What fitting did you use to connect it to the fuel rail? Thanks for helping me out !
Old Sep 9, 2016 | 01:58 PM
timd38's Avatar
timd38
The fuel rails should have come with fitting.
Here is what it says it comes with.
OE LS 3/8" Fuel Line to -6AN Fuel Line Conversion Fitting
-6AN Fuel Supply Line; 90°/45° Ends
-8AN Crossover Line; 90° Ends
Individual Fittings:
8 SAE (O-Ringed) To -8AN Fitting
8 SAE (O-Ringed) To -6AN Fitting
8 SAE (O-Ringed) To 1/8" NPT Fitting
8 SAE Plug (O-Ringed)
Old Sep 9, 2016 | 02:06 PM
Unreal's Avatar
Unreal
Sell them and get Holley's. Then order the tight 90 from fore or aeromotive banjo.
To Need Help ! Fast Fuel Rails
