Header install question?
Old Sep 9, 2016 | 01:12 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
Default Header install question?
Header install question.
Their is a electrical line going into the heads (Oem) from above the power packs. See picture below. First time I have seen this. I am just used to seeing the 0/2's. Under the blue in picture.
Am I going to have to make sure the headers come ready to receive these or is this a welding job?
PS; what are they?
Thanks in advance for any advise.
Robin
Old Sep 9, 2016 | 04:28 PM
jp_tt_awd's Avatar
jp_tt_awd
That is the upstream o2 sensor, your new headers should come with o2 sensor extension harnesses as the upstream sensors are moved a lot further downstream with headers. If not you will need to buy some.
-jp
Old Sep 9, 2016 | 07:47 PM
Dcasole's Avatar
Dcasole
If you are installing them make sure u purchase an O2 sensors socket , spray some rust buster and they will turn out easy ....
Dave
To Header install question?
