is alignment necessary after shock swap?
Old Sep 22, 2016 | 08:25 PM
torquetube's Avatar
torquetube
Originally Posted by timd38
Your saying that the shocks have enough charge to raise the car, that then means that the shock is carrying the load of the vehicle, because it raised the ride height. If that is in fact true, you don't need the springs because the shock have a higher spring rate than the springs.
It's not an either-or proposition. The spring exerts a big force on the lower control arm, and the gas-charged shock exerts a small one. They add together.
Imagine pulling up on the fender with your hand. The ride height raises a little. But the springs are still doing most of the work. It's not like you're holding up the car by yourself.
Old Sep 30, 2016 | 08:25 PM
Purple92's Avatar
Purple92
While I have seen posts that recommend an alignment after you pull the bolts that secure the upper control arms to do the front shock replacement - I DIDN'T see any way that the arms would be in a different place afterward - so when I did a shock change (to DRM valved Bilsteins) I did not get it re-aligned. I saw no measurable difference in ride height either. The shocks make a big difference.
Between the shocks and the replacement of the OE Goodyear runflats - the car's handling dramatically improved !!!
Old Sep 30, 2016 | 08:39 PM
cclive's Avatar
cclive
When I put on my Bilsteins, I saw no need to unbolt the control arms. I just tied them compressed with a piece of string.
Old Oct 1, 2016 | 05:30 PM
WW7's Avatar
WW7
I didn't unbolt my control arms either..I just used the zip tie method.. After compressing the shock on the bench , lock it in place with zip ties.. Once you get the shock bolted on the bottom A arm , cut the zip tie and guide the top into the upper hole...This makes installation very easy.....WW
