But i am a lil confused since these say they are for the front.. but are 13.38 inchs where the stocks are 14 for the front.. Also cant find any rear ones..
or could i go with these for the gto since we have the same bolt pattern?
Plenty of other 2 piece rotors for less money. Zip, Coleman, Wilwood, Racing Brake, Girodisc, etc.
I would not even consider those with the drilling and small aluminum section.
A few companies make rears, but you lose the parking brake since the parking break is a drum style on inside. When you do an aluminum center you can't use that for parking brake anymore.
Edit. My bad I'm dumb and they do have parking brake ones available, just heavier and more expensive.
hmm well shat lol. i guess if u make sure ur in gear all the time be fine but meh thats something to think about...what do the zr1s do?
I've had the Coleman two piece for 3-4 years now and they have the parking brake. 10 pounds lighter on the fronts, 6 on the rears.
Haven't seen aluminum center rears with parking brake. They have solid ones with it. Then again maybe I missed it. Then again I was looking for c5 base size rears.
My bad. Just checked and they do have them. Just cost more. $800+ for a few lbs in the rear just isn't even remotely worth it to me.
Ok let me clear this up because there seems to be confusion.
These are not Coleman two piece brakes. Coleman makes the rotor blank for us, that it. The rotor blanks are also custom and not off the shelf parts. Ours are the only ones that have aluminum hats and parking brake. There is a company that has a steel rotor with a steel hat for parking brake but the rotor is 15" and you have us an adapter on your caliper. There one rotor weighs the same as both of our rotors together.
Can't go wrong with these people. The are Corvette guys.
