Z51 gear ratio
Old Sep 28, 2016 | 11:34 PM
montman's Avatar
montman
Default Z51 gear ratio
Hello Friends,
I have an 08 automatic with the Z51 option. I am curious why the gear ratio is higher with this option. I'm old school and always thought lower gearing (for example 4.11) would give you much quicker acceleration than a higher gear - like say a 3.23 ratio - which keeps rpm's lower. My tach only shows 2200 rpm at 100 mph in 6th.
What difference would I feel driving a car without the Z51 option? I don't track the car -- but I give it an old fashioned Italian tune-up a few times a month though.
Thanks to all!
Old Sep 28, 2016 | 11:56 PM
HOXXOH's Avatar
HOXXOH
Your rear axle gear is 2.73 and the non-Z51 ratio is 2.56. Compared to the "old days" that sounds awful. However, 1st gear in the trans is 4.03, so your overall is 11.00. When you compare that to a 4.11 rear with a 2.56 1st gear in a Muncie 4-speed, that overall is 10.52. It's just a matter of changing trans gears and rear axle gears to get good emissions and gas mileage, while still having ratios to provide good acceleration.
There is no 1 to 1 gear in the trans. 4th is 1.15, 5th is .85, and 6th is .67.
Enjoy the gas saving overdrives, and the old school overall for the fun.
Old Sep 29, 2016 | 12:30 AM
Mike's LS3's Avatar
Mike's LS3
The 4 speed Muncie M21 with a 2.56 1st gear was considered the wide ratio. I had 4 speed Muncie M22 "rock crusher" with a 2.20 1st gear which was a close ratio transmission. Combine that with 3.73 gears (8.20 overall) and a solid lifter cam you get a soggy bottom end.
Back to the OP. The lower gears (higher numerical) will allow your car to come out of the corners quicker by keeping the rpms up little higher. So, for track or spirited driving it is a good thing!
Old Sep 29, 2016 | 09:52 PM
CMY SIX's Avatar
CMY SIX
your in a world class sports car capable of hitting 200 MPH, able to give Ferrari owners heart burn, not a drag car.
To Z51 gear ratio
