Good start. The trap speed tells me that the ecm is pulling timing up top or there's something else wrong. Live in a high altittude area? How was the DA? You should be trapping at least 130mph on a bad day.
I suggest to start monitoring and if you are planning to use drag radials be ready to buy a better clutch. I'm about to swap into my second clutch kit!
I have a twin disc clutch from monster clutch installed already.
I was running 130mph in the car, but have since put a gm crate engine in it as my other ls2 exploded lol.
I have not had the car re-tuned since.
it put down 610rwhp
I guess the engine is still being broken in? Good on the clutch! My mcleod rxt didnt last but 8k miles. I am bummed and will stop drag racing with the drag radials or remove the sc. Having this muh power becomes addictive and it just snowballs from there.
