Rocked my Corvette back and forth with my hand on the rear tire. Engine was off and in park.
Heard noise under rear and felt it in the wheel. Axle nut maybe?
Axle nut is easy to do, but look up the procedure, too, for torque number and loctite usage. (new lock nuts are inexpensive) If that doesn't work grab the wheel/tire to see if wheel bearing. You might also look at end links, too. All before trans or axle because these are less expensive!
Thank-you for the information. I will follow the procedure. On my C4 it was the wheel bearing.
Rotating the tire in a forward/rearward motion will feel play in the CV joints, differential, and transmission. A small amount of play is normal.
Wheel bearing play is felt by grabbing the tire at 6 and 12 o'clock and pushing with one hand while pulling with the other.
End link play is felt by grabbing the tire at 3 and 9 and doing the same push/pull.
Axle nut play is felt when doing both the 6 and 12 plus the 3 and 9 motions.
If you ever need to replace an axle nut ($2-3), after you locktite and torque it, take the old nut and add it on. You can check to see if it's ever moved by drawing a line on the nut and the axle.
Anybody know the proper torque for an axle nut? I have seen several listed here. I finally used 150# and used the old nut as a jamb. Just curious if any of you have the definitive torque.
Thanks for your information. Just cut down a tree and back is not too happy. Will use your info tomorrow. Applying medicine now
At one time the factory spec was 160 and later it changed to 140. I used 140 and with the jam nut too.
Mine kept coming loose at 150 ft*lbs. Gave them an extra bit of twist past that and they finally have stayed put. Probably 160-165 I'd guess.
Also, agree with previous answer.. if you're just moving the wheels around with everything off you're going to hear noises, that doesn't mean there's an issue.
Lifted my Corvette this mourning and did all movements. Wheel seems solid and no movement. Moving tire and wheel in direction of travel. I do have some play. This is too be expected. Thanks for your info and to the others that replied. The Forum is there to help.
Keep in mind that the axle nuts may not be backing off. Continual re-torquing, especially at the higher torque, may actually be stretching the axle. I have read where some axle failures by have been the result of over torque. It is a good idea to double nut the axle. That way you can not only keep nut tight at lower torque, but can tell if the nut has moved.
