Sudden drop in mpg
Old Oct 9, 2016 | 07:28 PM
justdrive's Avatar
justdrive
Default Sudden drop in mpg
I have a 2010 LS3 with an LS7 manifold-exhaust back
My car went from 30+ mpg to 26 mpg recently. Im suspecting the tune, MAF and O2 sensors. I just picked up HP Tuners. Can you guys teach me the basics to track down whats causing the parasitic loss in fuel economy?
Old Oct 9, 2016 | 07:29 PM
justdrive's Avatar
justdrive
I should add a component in my AC belt, when it's on I get a terrible cabin vibration between 1200-2400 rpm. I pulled the belt, I figure one thing at a time.
Old Oct 9, 2016 | 08:59 PM
Boomer111's Avatar
Boomer111
HB problems?
Harmonic Balancer..
Old Oct 9, 2016 | 09:40 PM
justdrive's Avatar
justdrive
@Boomer111
Does this sound like the HB causing all of this? Right now it sounds like a cricket at idle and it wobbles pretty bad. Did I save my AC compressor?
Is the LS3 crank pinned or do I need a speed shop to pin it for the ATI?
Originally Posted by Boomer111
HB problems?
Harmonic Balancer..
Old Oct 9, 2016 | 09:55 PM
emoFTW's Avatar
emoFTW
Originally Posted by justdrive
@Boomer111
If it's wobbling bad, I would get that replaced ASAP. I've read somewhere on here where a guy trashed his crank from a wobbling HB. Not sure if it's possible/true. No the crank does not need to be pinned for the ATI dampener.
Old Oct 9, 2016 | 10:03 PM
justdrive's Avatar
justdrive
If thats the case, the crank runout will trash the new one, so pinning makes sense.
Please add more! -JD
Old Oct 10, 2016 | 07:45 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
I would go and have the computer read. See if any codes have been set.
The 0'2 would set off that engine sign on dash.
I have never seen 30mph though? I think that 26 ish is normal with the cruise on.
To Sudden drop in mpg
